Switching Batteries Advice?
Old January 6th 06, 06:53 PM posted to rec.aviation.soaring
Default Switching Batteries Advice?
Brian wrote:
I really can't see any drawback to the make before break switch other
than cost and availablity. As long as you have appropiate fuses or
circut breakers in the system fire should not be an issue and 99.99% of
the time you will only be switching from a low battery to a good
battery. and the two batterys are only connected for a few milliseconds
which may not be such a bad thing as it will slightly slow the voltage
transition to your instruments.
Based on my experiments with two 18 amphour batteries, one freshly
charged and the other discharged below 10 volts, the "surge" current
will be less than 10 amps. For the more typical case (two 7 amphour
batteries, one fresh and one discharged to 11 volts or so), the surge
current will be only a few amps. This is well within the capacity of
switches, wires, and fuses commonly used, especially given the short
duration.
Eric Greenwell
Washington State
USA
Battery Source Mike the Strike Soaring 81 October 28th 05 01:46 AM
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 03:32 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
boot camp advice jameson Military Aviation 17 July 22nd 04 06:12 AM
Rechargable AA batteries and chargers TripFarmer General Aviation 2 October 17th 03 07:34 PM
