Tow Out Gear
Old January 8th 06, 06:23 AM
Gadget Guy Gadget Guy is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
Exclamation Tow Out Gear
I have recently purchased a DG-300, and am in the process of getting it ready to fly this next season. If you have any equipment you are looking to sell, Please forward me pictures and price.
I need a wing wheel, one man rigging unit, tow bar.
Send to jschaffer at techno-mation dot com.
Old January 8th 06, 10:12 PM posted to rec.aviation.soaring
Default Tow Out Gear
I don't have any gear to sell you, but I do have some well meaning
advice - don't buy a Cobra one man rigger. I found the Cobra rigger to
not only be expensive, but also clumsy and awkward to use. It was
difficult to get it close enough to the fuselage of my ASW-19B when
loading the wing from my Cobra trailer; it was very hard to move the
wing from side to side between the wheels when rigging the second wing;
and the little kickstands did not properly lock in position.
My comparison rigger was a homebuilt unit called the Lewis Loader. The
Lewis Loader was lent to Tool-Tech, and they now produce one man
riggers based upon its design features. This is most probably the
rigger that I'll be buying.
Hope this is helpful to you.
-John
Note: I have absolutely no connection with Tool-Tech or its
distributor.
Old January 10th 06, 04:57 PM posted to rec.aviation.soaring
Is this the same Tool-Tech rigging aid that Wings and Wheels sells? I
am trying to compare the 3 riggers that I can find available in the US
(Wings and Wheels, Udo, and M&M) and really cannot make a decision.
The wing holding cradle on the Wings and Wheels model seems like it
might be less good on a flapped wing because it appears to grab the
wing on the trailing edge. The Udo and M&M models seem to be almost
identical in that regard, but the M&M does not have the horizontal
adjustment option. Shipping from M&M is about half of what Udo asks.
Anyone have any advice here? I cannot find anyone at my club who knows
about these, and the only thing keeping me from ordering today is that
I really cannot figure out which to order! Wish that I could go to the
SSA convention to look for myself....
Thanks.
Old January 10th 06, 07:25 PM posted to rec.aviation.soaring
Yes, Wings & Wheels sells the Tool-Tech rigger I referred to. I can't
speak to its use on a flapped wing, as Standard class machines were all
I rigged. In use, the only force from the trailing edge grip would
occur if the wing tried to twist or slide out of the holder. For a
flapped machine you'd definitely want to know if the grip extended far
enough forward to bear on the top surface of your wing. I have heard
that minor modifications are planned for the Tool-Tech rigger - maybe
this is one of them, you'd have to ask Tim Mara.
For me, horizontal adjustment is important. Udo's rigger uses brass
inserts riding on a square shaft, while the Tool-Tech uses linear
bearings on a rod. The Lewis Loader proved to me that metal on metal
makes it hard to adjust precisely, so the linear bearings are a
definite plus. Also, the Tool-Tech appears to offer a larger horizontal
adjustment range than Udo's, which is also useful to me.
As you can see, I've pretty well made up my mind on the Tool-Tech. FYI,
there is another rigger available in the USA, the WingMate from Chip
Bearden. Check out his site:
http://members.aol.com/wingstand/alternatives.htm Be sure to check out
his link "Other Ways to Do It" for additional input on pros and cons.
-John
P.S. - I don't know the M&M model - do you have a link?
Old January 10th 06, 08:19 PM posted to rec.aviation.soaring
I should have said MM Fabrication. I have seen one of the trailers
that they have made and it appears to be very well done. Thanks for
your help.
http://www.mmfabrication.com/
Old January 11th 06, 04:33 AM posted to rec.aviation.soaring
I met Mark Mocho at M&M last week. I, too, am looking for a 1-man
rigger. I was impressed with everything I saw. He has an option for the
fore/aft adjustment, I believe. Outstanding workmanship and a good guy.
I wouldn't hesitate to order one, except that my son is now building
one for me for a ... very ... late Christmas present. Gotta wait and
see how that comes out. I looked at his wing wheels and tow dollies,
too. All of it is first rate.
Jack Womack
Old January 11th 06, 05:51 AM posted to rec.aviation.soaring
Mark Mocho's (MM Fabrication) wing wheels and tow-out bars are the best
in the business too.
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 30th 05 12:17 AM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 02:59 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
