Cal Vanize wrote: In reviewing the definitions from the FAA na dfrom comments posted in this newsgroup, there seem to be some special opportunities when building aircraft that could fit LSA derfinitions. If my understanding is correct, it would be possible for someone to build (for instance) a Van's RV-6a with a Lyc O-235 or Conti O-200 and a ground adjustable prop set to its extreme climb configuration to limit speed to 138 mph. As long as the plane's max TOW is stated to be 1320 lbs, that would fit the LSA category. Is this assumption correct? TIA, CV That should say RV-9a, not RV-6a. The RV-9a is stated by Van's to use a 118hp O-235. |
| Thread Tools | |
| Display Modes | |
| Mechanical Systems Certification Engineer-Aviation | [email protected] | Home Built | 0 | April 2nd 05 09:25 PM |
| Adding IFR Plane Certification To Planes Without It | Blanche Cohen | Owning | 10 | November 29th 04 07:37 PM |
| Aircraft certification questions. | psyshrike | Owning | 42 | November 22nd 04 07:10 PM |
| certification of composite aircraft | sebastian | Home Built | 6 | March 25th 04 04:48 PM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
