Iced up Cirrus descends by BRS
Old January 16th 06, 04:56 PM posted to rec.aviation.piloting
Default Iced up Cirrus descends by BRS
Friday, an iced up Cirrus came down under BRS. Just a bit northwest of
where I live here in Alabama. According to the newspaper, it took off
out of Birmingham and iced up climbing through clouds, stalled, and the
pilot popped the BRS. Came down in a tree. Pilot and passengers
uninjured.
Old January 16th 06, 05:35 PM posted to rec.aviation.piloting
"Wallace Berry" wrote in message
uninjured.
Icing in Alabama, damn.
DW
Old January 16th 06, 05:43 PM posted to rec.aviation.piloting
uninjured.
And the reports seem to glorify the BRS yet nothing is mentioned of
why the pilot entered icing conditions and if that should have been
anticipated.
Ron Lee
Old January 16th 06, 08:37 PM posted to rec.aviation.piloting
anticipated.
Ron Lee
Another point to consider, weather conditions on the ground at that time
were quite good. Birmingham reported about 4300 Broken, temp +9C.
Montgomery had 3500 Scattered, +14C. Odds are, he could have just
descended into warmer, clearer air, shed the ice, and flew on, a bit
wiser and scareder(sp?). We'll never know, of course, and you can't
argue with "success", but I have to wonder about this "pull the chute if
anything is amiss, and let the chips fall where they may(so to speak)"
mentality that the BRS types advocate. Someday, someone's going to get
hurt, when they didn't have to.
Happy Flying!
Scott Skylane
Old January 16th 06, 09:19 PM posted to rec.aviation.piloting
"Scott Skylane" wrote in message
anticipated. Ron Lee
descended into warmer, clearer air, shed the ice, and flew on, a bit wiser
and scareder(sp?). We'll never know, of course, and you can't argue with
"success", but I have to wonder about this "pull the chute if anything is
amiss, and let the chips fall where they may(so to speak)" mentality that
the BRS types advocate. Someday, someone's going to get hurt, when they
didn't have to.
Happy Flying!
Scott Skylane
That's true in any situation and our Armchair Quarterbacking will always
make sense after the fact. But if the thing truly did go out of control I
don't think I would "hope" that a warmer lower level would shed the ice and
allow me to regain control, assuming of course the wings stayed attached. I
think I'd rather read that the chute "saved" the lives of 3 GA pilots and
passengers instead of another GA plane crash in bad weather that caused the
plane to "stall". The chute, whatever your opinion as a pilot, is a good PR
story for GA.
DW
Old January 16th 06, 09:25 PM posted to rec.aviation.piloting
The chute, whatever your opinion as a pilot, is a good PR story for GA.
I'd like to suggest an alternate interpretation: These ballistic
chutes are good PR for ballistic chutes. They're poor PR for the 99%
of planes that don't have them, and only reinforce the opinion in the
minds of the public that small planes are inherently unsafe UNLESS they
have chutes.
A non-aviator sees one of these stories and doesn't think "Wow, I guess
these planes are safer than I though!" They think "Wow, he sure was
lucky that plane happened to have a parachute."
Ben Hallert
PP-ASEL
Old January 16th 06, 09:27 PM posted to rec.aviation.piloting
You think ice builds up slowly? Think again. In thirty to sixty
seconds your wings can become unusable. Flying into clouds in the
Winter. DDDuuuuuhhh
Old January 16th 06, 10:59 PM posted to rec.aviation.piloting
anticipated.
Ron Lee
Ok, so the PIREP shows severe icing at 7700 to 9000'. Ground temp at
Montgomery +14C. Assume 3 degree decrease per 1K feet and freezing
level may have been around 5000'. Temps below freezing and in clouds.
Now is that conducive to icing?
Ron Lee
Old January 16th 06, 11:05 PM posted to rec.aviation.piloting
uninjured.
anticipated.
Yes, it'll be fun to see the stats after a few more years of experience.
I'm still betting that the BRS system encourages more risk taking and
I'll bet that this will, in the end, overcome any safety advantage from
the chute and cause the overall safety record of the Cirrus to be as
bad, or even worse, than similar non-chute aircraft.
And for this you carry around extra weight, pay more money and have an
explosive device always onboard!
Matt
Old January 16th 06, 11:06 PM posted to rec.aviation.piloting
didn't have to.
Happy Flying!
Scott Skylane
story for GA.
Baloney. They may be good PR for Cirrus, and I've long suspected this
was the only motivation behind including them, but they are lousy PR for
GA overall.
Matt
Cirrus demo Dan Luke Piloting 12 December 4th 05 06:26 AM
Iced up Cirrus crashes Dan Luke Piloting 136 February 16th 05 08:39 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 11th 04 12:30 AM
New Cessna panel C J Campbell Owning 48 October 24th 03 05:43 PM
