Approach to an LOM/IAF with PT (not vectors to final)
Old April 9th 04, 08:50 PM
O. Sami Saydjari
Default Approach to an LOM/IAF with PT (not vectors to final)
The Approach in question is SDF RWY 2 at KISW. I was coming in from the
south, nearly lined up with the inbound course of 021 degrees. I was in
touch with ATC. The LOM/IAF is called NEPCO. The ATC asked if I wanted
"direct NEPCO." I said yes. Within about 10 miles of the airport, the
controller said that frequency change was approved. I believe I was out
of radar contact by this time (radar coverage in the area is spotty).
1. Since there is no "NO PT" indicated on the chart, does that mean that
I am required to do a 180 deg turn when I reach NEPCO so I can track
outbound (201), then do a PT, then come back? That seems a little odd
to me.
2. If so, and I am assuming it is, should I have positioned myself to
approach NEPCO at an intercept that did not require a 180 deg turn to
get to the outbound course? Maybe come at it from the east?
3. Suppose that when I reach NEPCO (IAF), I am below the cloud deck.
Assume that I have switched over to unicom frequency at that point. Is
it permissible to abort the IFR approach and turn inbound for a visual
approach. Presumably, you would have to ask ATC permission to do this.
What if you can not raise ATC on the radio? Can you go visual on your
own?
-Sami
N2057M, Piper Turbo Arrow III
Old April 9th 04, 11:32 PM
I'm kind of confused.
When or how did he actually clear you for the approach?
If he cleared you for the appoach and also cleared you direct NEPCO, then
you just shoot the approach straight in on the SDF once established on the
localizer. Since you were approaching from the south, no procedure turn is
necessary.
If he only cleared you to NEPCO, but didn't clear you for the approach, then
you should expect further clearance or enter the hold.
I don't think he would have given you a frequency change if he expected you
to do the full approach including the procedure turn, I'd only expect to get
the hand off after I was inbound crossing the IAF.
Jim Burns III
Remove "nospam" to reply
"O. Sami Saydjari" wrote in message
to me.
own?
-Sami
Old April 9th 04, 11:35 PM
O. Sami Saydjari
He cleared me for the approach about 10 miles out and then approved a
freq change. The paproach does not say "NO PT", so is it legit to
assume that I do not need to do one?
necessary.
It does not say that in the approach plate.
Old April 9th 04, 11:38 PM
Michael
to me.
Technically yes, you are required to do this. If there's no RADAR,
who is going to know if you do or not?
Not really. Your cleared route is direct NEPCO, so that's what you're
expected to do.
Right. Or simply cancel IFR.
Then you have a comm failure in VFR conditions, right? So continue
under VFR and land as soon as practicable as per 91.185(b).
Yes, I know I'm stretching the meaning of the reg, but realistically
that's what makes sense.
Michael
Old April 9th 04, 11:58 PM
The exeption to the rule when NoPT is absent from the chart is when you are
cleared straight in either via radar vectors or via a clearance, otherwise
you are expected to do the PT when you arrive over the fix that begins the
procedure turn. Because you were given a radio hand off to the local
frequency, I would have taken that to mean you were cleared straight in via
your clearance to NEPCO, but when in doubt ask, because as you say, you were
probably below radar coverage. I would have responded with something like
"N1234 cleared direct NEPCO, straight in SDF 2, frequency change approved"
That's usually what I do when comeing from the north into STE on the GPS 21
and I usually get a "roger" or "read back correct". If he wants you to do
the full procedure turn that would give him a chance to make his clearance
clearer
Jim Burns III
then
is
necessary.
then
you
get
Old April 10th 04, 12:20 AM
Another option. You could use the hold for a course reversal. "Roger
Minneapolis, cleared for the SDF 2, direct NEPCO, we'd like to do a lap in
the hold rather than the procedure turn." This would be a little quicker
because the holding fix is NEPCO. Right turn outbound, right turn inbound,
straight in and land.
Jim Burns III
to me.
own?
-Sami
Old April 10th 04, 04:18 AM
O. Sami Saydjari
Jim, I like your idea on reading back for a straight-in. The thing
about doing a turn around the hold is that it seems to me to defeat the
whole purpose for the PT. As I understand it, the approaches have you
do this so that you are well-established on the SDF/ILS *before* you get
to the LOM. In this case, the PT or hold serves to destablize your
track and decrease safety. At least, that is how I see it.
-Sami
Old April 10th 04, 04:28 AM
Brad Z
The hold is for the missed approach. If the designer of the approach had
intended to use the hold as a course reversal method, he/she would have
designed it that way. If you have not been advised that you are being
vectored for the approach, substituting a lap in the hold for a procedure
turn doesn't make it any more legal than omitting the PT altogether.
Besides, ATC can't rewrite the approach procedure, especially if they can't
see you.
"Jim" wrote in message
inbound,
Jim Burns III
to me.
own?
-Sami
Old April 10th 04, 04:53 AM
Brad Z
Yep, if you heard anything along the lines of "Vectors for the approach" in
your clearance, this whole discussion is moot.
to me.
According to the rules, yes, and technically ATC expects you to follow the
rules. More than likely, however, your controller expected you to continue
inbound without flying the PT. You could clarify the situation by
indicating that upon reaching the LOM you would be making a right turn to
track the FAC outbound for the published course reversal. This would likely
be replied with a "N12345 roger, report PT inbound" or something similar.
There is nothing in the AIM that makes an NoPT exception when you're already
set up on the FAC in non-vectoring situations. If you're not on a
transition with a NoPT note, or some other circumstance noted on the
approach procedure that excludes flying the PT, the PT must be flown.
Not necessary. Whatever is the most direct and allowable means of reaching
NEPCO is fine.
1) cancel IFR
2) Request Visual or Contact Approach
3) Land, assuming you meet the requirements of 91.175c
Unless you're NORDO, you're required to contact ATC anytime you deviate from
a clearance.
own?
You're NORDO in VFR, just land, and cancel IFR on the ground.
-Sami
Old April 10th 04, 04:56 AM
Stan Gosnell
to me.
NoPT means you cannot do a procedure turn without specific authorization
from ATC. You continue straight in. No means no.
own?
Why would you do that? Presumably the approach leads to the airport, so
following the localizer or approach guidance will be the shortest route to
the airport. Once you have the airport in sight, you can maneuver as
necessary to land if you have to circle to a different runway.
Have you had no instrument training? All this should have been covered in
detail in any instrument instruction.
Regards,
Stan
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
Why an NDB approach with a miss to an intersection? Ben Jackson Instrument Flight Rules 10 March 25th 04 04:53 AM
Changes to Aircraft Approach Categories?! skyliner Instrument Flight Rules 10 February 9th 04 09:55 PM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 06:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
