("Jim Macklin" wrote)
But all batteries wear out because lead flakes off the plates and collects in the bottom of a standard lead/acid battery [that's why the plates do not extend all the way to the bottom of the case, the space is there to collect lead sludge. When the sludge touches the plates they short out and the cell is dead.] Would sucking out the sludge/flakes, once in a while, extend the life of the battery? Drain (filter) back any acid/water into the cells. Has anyone tried this? Montblack |
There really isn't space to clean the sludge and if you
invert the case, you just dump the sludge into the plates. I don't know of any batteries with a drain/cleanout plug on the bottom. Battery recyclers rebuild batteries by cutting the top open and washing the plates and reinstalling them into clean cases. But the plates are worn and the life of the battery would be shortened. I don't think any aircraft batteries are rebuilt this way, usually the metals are melted down and new batteries manufactured. NiCad batteries use individual cells and those cells can be swapped into a case and the cells are remanufactured under careful controls. Of course NiCad batteries used in KingAirs and jets cost as much as a small car. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Montblack" wrote in message ... | ("Jim Macklin" wrote) | But all batteries wear out because lead flakes off the plates and collects | in the bottom of a standard lead/acid battery [that's why the plates do | not extend all the way to the bottom of the case, the space is there to | collect lead sludge. When the sludge touches the plates they short out | and the cell is dead.] | | | Would sucking out the sludge/flakes, once in a while, extend the life of the | battery? Drain (filter) back any acid/water into the cells. | | Has anyone tried this? | | | Montblack | |
"Jim Macklin" wrote Of course NiCad batteries used in KingAirs and jets cost as much as a small car. Anyone ever seen a cutaway or the real insides of one of those big Nicads used in Jets? I sure would like to see how they are made. -- Jim in NC |
Each cell is a metal case with terminals. They are slide
into the larger case and connected with bus bars to complete the circuit. http://www.saftbatteries.com/020-MS_..._advantage.asp http://www.saftbatteries.com/020-MS_...cteur=Aircraft -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Morgans" wrote in message ... | | "Jim Macklin" wrote | | Of course NiCad batteries used in KingAirs and | jets cost as much as a small car. | | Anyone ever seen a cutaway or the real insides of one of those big Nicads | used in Jets? I sure would like to see how they are made. | -- | Jim in NC | | |
| Thread Tools | |
| Display Modes | |
| Crash In The Nolichucky | W P Dixon | Piloting | 2 | June 22nd 05 05:16 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 06:43 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
