Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ?
Old February 1st 06, 06:34 PM posted to rec.aviation.owning
Default Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ?
Do you have a mechanic to work with who will sign off a field
rebuild...
You might consider sending the case, crank, cam, con rods, to Divco for
IRAN and balancing (or Aircraft Specialities, etc.) along with the new
cylinders of your choice of brand... Press new bushings in the rocker
arms... Send the carb, alternator, vac pump, oil pump, for overhaul...
Overhaul the mags and install with new wires and new hoses... Then
with your mechanic put it back together... This should be less than
the highest bid you had for an overhaul and will give you the
equivalent of a new engine...
denny
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Gyrocopter Speed Mark Rotorcraft 36 August 17th 05 12:28 AM
Towing Roger Fowler Soaring 6 August 11th 05 05:25 AM
Need PAN and Rear ACCESSORY CASE Gaskets For 0-435 Lycoming Engine Spar Home Built 5 March 30th 04 11:09 PM
