Andreas Maurer wrote:
Any current airliner features an L/D better than 20:1 with engines off. Cite? Jack |
On Mon, 13 Feb 2006 07:10:06 GMT, Jack wrote:
Andreas Maurer wrote: Any current airliner features an L/D better than 20:1 with engines off. Cite? For a gerneral overview, look here at a phantastic NASA report: http://www.hq.nasa.gov/office/pao/Hi...468/ch12-2.htm --- Start quote --- Abut the B-47 (of 1948!) it says: The thin, high-aspect-ratio swept wing of the B-47 coupled with its long high-fineness-ratio fuselage contributed to the high aerodynamic efficiency of the aircraft. The maximum lift-drag ratio of about 20 is the highest of any aircraft yet considered in this book, and the zero-lift drag coefficient was a low 0.0148 707: The aerodynamic efficiency of the 707-320B may be judged by the value of the maximum lift-drag ratio, which is estimated to be in the range from 19 to 19.5. 747: The aerodynamic configuration of the 747 is very similar to that of the 707. The 747 wing has slightly more sweepback than that of the 707 and is of about the same aspect ratio. An improved airfoil design is also incorporated in the wing of the 747. The maximum lift-drag ratio of the aircraft, (L/D)max, is estimated to be about 18, as compared with a value somewhat over 19 for the 707, The lower value of (L/D)max, results from a higher value of ratio of wetted area to wing area on the 747 than on the 707. DC-10/Tristar: The aerodynamic design of both of the three-engine jet transports is conventional. The wings of both aircraft have about 35° of sweepback with aspect ratios in the range of 7.0 to 7.5 and feature transonic airfoils of advanced design. The wings have double-slotted trailing edge flaps and leading-edge slats. Lateral control is provided by a combination of ailerons and spoilers. The spoilers are also used to control lift and drag when deployed symmetrically. Longitudinal control of the L-1011 is provided by a variable incidence stabilizer to which the elevator is mechanically linked. The DC-10 employs separately actuated elevators and stabilizers. Neither aircraft employs longitudinal trim tabs. The maximum lift-drag ratio of the two aircraft is estimated to lie in the range between 17.0 and 17.5. --- End quote --- With a little searching it should be simple to fnd the numbers of current airliners which feature significantly higher aspect ratio, resulting in an increase of L/D over the older airliners mentioned here. I haven't seen any official numbers yet, but for the Airbus 340 max L/Ds between 16 and 24 can be found on a quick search on the net - I tend to believe that it's provavly a little over 20 due to the high aspect ratio of the 340. Bye Andreas |
Just found on an other site (http://www.luftpiraten.de/glos_g32.html): Wright Flyer 8.3 Cessna 172 10 Now that's what I call progress! Stefan |
| Thread Tools | |
| Display Modes | |
| Virgin Globalflyer finally takes off | John Doe | Piloting | 2 | February 9th 06 02:07 AM |
| Atlantic Tow?? | Ed Byars | Soaring | 14 | October 9th 05 04:22 PM |
| X-C from NC to FL over Atlantic ? | John Doe | Instrument Flight Rules | 20 | July 11th 05 04:50 PM |
| Air Ops North Atlantic - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 1 | June 4th 05 07:52 PM |
| Scaled Composites will build Virgin Galactic's fleet of five spaceships | Larry Dighera | Piloting | 3 | January 5th 05 03:36 PM |
