sizing solar panel
Old February 16th 06, 04:55 AM posted to rec.aviation.soaring
Default sizing solar panel
Udo Rumpf wrote:
If I want to maintain a 12 volt 7amp/h Battery with a solar cell panel
what rating would I need during flight, if after 4 hrs I wanted to have
a usable, not full, charge in my 12 Volt battery.
Right now, my as good as new battery is useless after 4 hours.
This suggests you are drawing about 1.5 amps from your battery, which is
very high, even for a glider with a transponder. Is that right? Can you
reduce the drain safely by turning something off?
and what size would the panel be?
It would have be about a 1 amp maximum output panel just to be sure of
getting 0.5 amps on average, which would leave ~2 amphours to the battery
after a 4 hour flight. About 1+ hours of use would remain at your 1.5 amp
drain. That's a rather large solar panel to mount on glider, or a rather
expensive one.
If you are really drawing 1.5 amps and can't reduce it, I'd suggest first
putting in another (or bigger) battery. Cheaper and easier, I think.
Eric,
As per manuals I draw about 1.1 amps without talking on the radio
I can fly for about 4 hours and I drop to 12 volts from fully charged
7 amp/h battery. Add an other 1.4 amps for transmit.
Regards
Udo
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Piloting 7 March 14th 05 08:36 AM
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Soaring 7 March 14th 05 08:36 AM
Why not a hinged panel? Jay Honeck Owning 22 March 8th 05 12:15 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 03:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
