sizing solar panel
Old February 16th 06, 01:38 PM posted to rec.aviation.soaring
Default sizing solar panel
Udo,
When our Club's Orion arrived it apparently chewed through batteries at
a high rate. After some time, we found that the spec sheet for the
diode installed to protect against reverse polarity had a huge 1.2V drop
across it.
As a result, the charger wasn't charging to anywhere near full capacity
because the battery only saw 12.6V when the charger saw 13.8V.
Accordingly, it appeared as though the instruments were drawing much
more current than they were. It took quite a while to find the real
problem.
Does this fit your case?
In the course of troubleshooting, we also found the interesting fact
that the cheap $20 SLA chargers (usually a sealed black plastic box from
China) have target voltages which varied from 13.3V to 15.8V for the
sample we tested. 3 out of 5 were around 15V.
My DG has a factory fitted diode in the system with a 0.3V drop. The
manual specifies that a charger charging to 14.1V is needed to charge
the batteries completely. I suspect that a number of the debates on
batteries on this forum are related to diode voltage drops. My
electronic guru pointed out that ALL diodes had a forward voltage drop
and some are quite large.
Graeme Cant
Udo Rumpf wrote:
If I want to maintain a 12 volt 7amp/h Battery with a solar cell panel
what rating would I need during flight, if after 4 hrs I wanted to have
a usable, not full, charge in my 12 Volt battery.
Right now, my as good as new battery is useless after 4 hours.
and what size would the panel be?
Udo
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Piloting 7 March 14th 05 08:36 AM
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Soaring 7 March 14th 05 08:36 AM
Why not a hinged panel? Jay Honeck Owning 22 March 8th 05 12:15 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 03:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
