Volt / Ammeter
Old February 17th 06, 07:07 PM posted to rec.aviation.homebuilt
Default Volt / Ammeter
Yeah, I'll give you that I missed the "powered from the measured voltage"
part. It becomes a bit less trivial. Practically impossible.
As for sticking pins through the wire a foot apart, you are going to get
more contact resistance (and corrosion as time goes on) than the shunt
itself. If you are using the primary wire as the shunt, I'd break the wire,
use a terminal strip with a shorter piece of thinner wire a few inches long,
then back to the larger wire.
"GeorgeB" wrote in message
On Thu, 16 Feb 2006 21:35:15 -0800, "RST Engineering"
Yes, rather trivially.
Stick 2 pins through the
insulation about a foot apart and hook them to the meter.
Old February 18th 06, 06:20 AM posted to rec.aviation.homebuilt
Would AC amps and DC amps read the same given a single meter switched
between the two?
Dan, U.S. Air Force, retired
Old February 18th 06, 12:12 PM posted to rec.aviation.homebuilt
between the two?
G'day Dan,
they will normally read pretty close, but the meter (and you get what you
pay for...) will read an average of the applied AC or voltage.
This difference in reading will apply more to non-sinusoidal waveforms.
Some of the fancy meters will read "True RMS", but for most typical
applications a cheap meter will be close enough. To check the alternator
output in an aircraft....... Well, you could always log the data and apply a
calibration correction if you needed to be super-accurate.......
Hope this helps,
Peter
Old February 21st 06, 08:20 AM posted to rec.aviation.homebuilt
On Fri, 17 Feb 2006 10:07:50 -0800, "RST Engineering"
I'm wondering if the OP may have mis worded, or mis understood.
As you say the measurement is trivial, however I'm wondering if he
didn't think of powering the meter from the same source as was
*providing* the current rather than the current being measured. That
would make sense. Then it'd be easy and as you said, practically
impossible if powered from the *measured* current.
www.rogerhalstead.com
Old February 21st 06, 11:59 PM posted to rec.aviation.homebuilt
"Roger" wrote in message
wire,
long,
What am I missing here? A good old fashioned analog ammeter is powered from
the "measured current".
Or, you can use a Simpson panel meter with your shunt. No power required. Of
course, they cost a fair bit of change nowadays.
http://www.simpsonelectric.com/pdf/w...-Vue%20ADC.pdf
You only need "power" if you want some kind of fancy pants digital readout.
Geoff
Spell checking is left as an excercise for the reader.
Old February 22nd 06, 02:07 AM posted to rec.aviation.homebuilt
Go back to the original post and read it.
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
from the "measured current".
Old February 22nd 06, 02:49 AM posted to rec.aviation.homebuilt
"RST Engineering" wrote in message
oops, missed the word "digital". Never mind.
Geoff
Cherokee ammeter revisted Leo Owning 3 January 15th 05 01:14 AM
Panel volt meter Bob C Soaring 10 January 13th 05 01:00 PM
Bouncing ammeter hand on 76 Warrior Leo Owning 5 December 5th 04 09:24 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 02:37 AM
28 volt pitot heat B2431 Home Built 15 April 17th 04 04:25 PM
