"Nicholas Kliewer" wrote...
I live in Dallas, TX and don't get out of the flat lands much. This Fall, I am planning a trip to Oregon in a C172 and figure that I could use some mountain flying training. Take a look at the WA State DOT Aviation Division at http://www.wsdot.wa.gov/Aviation/. They coordinate the Search & Rescue training courses, and I believe mountain flying is part of it. E-mail them if a current course is not listed. You might have to register as a "WA Pilot" to get their services, but the $15 should be worth it... |
![]() "Nicholas Kliewer" wrote in message = ... =20 =20 Does anyone know of any other pilots that have done this type=20 of trip in a C172? =20 =20 Thanks! =20 -Nick I once took a 172 with one passenger from Las Vegas to John Wayne, and we picked up enough ice in climb that we were unable to reach 12000. So ATC let us go WAFDOF at 11000, which was still above MEA. The mountain waves were very interesting that day! If your 172 will be loaded heavily, you will see very poor climb rates at those high altitudes. Be experienced in leaning for maximum engine power in climb, or else you may not make it. ---JRC--- |
Rule of thumb for mountain flying is to be *at least* 10% under
the max weight. For my cherokee (that tops out at 2400) that means absolutely no more than 2160. As a rule, during the summer I try to keep it under 2100 (thank you, density altitude) |
Andrew Sarangan wrote:
Rule of thumb for mountain flying is to be *at least* 10% under the max weight. For my cherokee (that tops out at 2400) that means absolutely no more than 2160. As a rule, during the summer I try to keep it under 2100 (thank you, density altitude) No one will fault you for keeping 10% under gross, but I don't think that is really necessary. Most runways in the mountains are plenty long for a 172 or cherokee. If you look up the performance data and add 20% for pilot and aircraft performance, there will not be many runways that are shorter. After all, if a runway is too small for a 172, how many other aircraft can really use that runway? I'm guessing that it's not the runway that's Blanche's limiting factor. I do not fly in the mountains, but I often do fly my Warrior II up around 10,000 ft to get above the weather and the turbulence, not to mention some of the bozos flying pretty-much randomly down at the lower altitudes. Once I get above 6,000 ft or so and am loaded close to my maximum gross weight, especially on a warm afternoon with lots of thermal activity, my Warrior's climb becomes unpredictable. On *average*, I still get the climb rate published in the POH, but sometimes a downdraft will overwhelm me for a few seconds or even a few minutes, and I am unable to climb or even to maintain altitude; other times, I'll shoot up like a rocket when I hit an updraft. That kind of unpredictability does me no harm when the closest obstacle is many thousands of feet below me, but I can see how it would be lot scarier crossing mountain ridges, especially with the stronger downdrafts from mountain waves, etc. Flying a bit under gross, at least in a normally-aspirated 160 hp or 180 hp plane, should give you much more of a fighting chance in a downdraft at high altitude. All the best, David |
![]() "Andrew Sarangan" wrote in message om... (Blanche Cohen) wrote in message ... Rule of thumb for mountain flying is to be *at least* 10% under the max weight. For my cherokee (that tops out at 2400) that means absolutely no more than 2160. As a rule, during the summer I try to keep it under 2100 (thank you, density altitude) No one will fault you for keeping 10% under gross, but I don't think that is really necessary. Most runways in the mountains are plenty long for a 172 or cherokee. If you look up the performance data and add 20% for pilot and aircraft performance, there will not be many runways that are shorter. After all, if a runway is too small for a 172, how many other aircraft can really use that runway? We're not talking about unobstructed runways but those that are carved out of the trees. If you only have a 172 or cherokee you need to be at least 10% under gross. You may get it off the ground but if you can't be guaranteed 500 fpm climb you have no business trying a takeoff until it gets cooler or you get lighter. |
(Blanche Cohen) wrote in message ... Rule of thumb for mountain flying is to be *at least* 10% under the max weight. For my cherokee (that tops out at 2400) that means absolutely no more than 2160. As a rule, during the summer I try to keep it under 2100 (thank you, density altitude) No one will fault you for keeping 10% under gross, but I don't think that is really necessary. Most runways in the mountains are plenty long for a 172 or cherokee. If you look up the performance data and add 20% for pilot and aircraft performance, there will not be many runways that are shorter. After all, if a runway is too small for a 172, how many other aircraft can really use that runway? I stand with Blanche on this one... it is NOT a runway length issue. As you state, the mountain runways are long enough. The reason for operating 10% under max gross weight is performance. In the mountains the critical issue is climb performance. The difference between 50 FPM and 200 FPM will allow a great reduction in pucker factor. :-) Best regards, Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 197 Young Eagles! |
In article , wrote:
Andrew Sarangan wrote: [snip] No one will fault you for keeping 10% under gross, but I don't think that is really necessary. Most runways in the mountains are plenty long for a 172 or cherokee. If you look up the performance data and add 20% for pilot and aircraft performance, there will not be many runways that are shorter. After all, if a runway is too small for a 172, how many other aircraft can really use that runway? I stand with Blanche on this one... it is NOT a runway length issue. As you state, the mountain runways are long enough. The reason for operating 10% under max gross weight is performance. In the mountains the critical issue is climb performance. The difference between 50 FPM and 200 FPM will allow a great reduction in pucker factor. :-) Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard Of course what Jer/ doesn't mention is that I learned it from him during the mountain flying course! See? I *was* paying attention! |
![]() Nicholas Kliewer wrote: Would you suggest that I take the mountain flying course somewhere else? I was wondering about doing it at Salt Lake City or Logan, UT since that's a little closer to the area that I'll be concerned about. If you can find a good course in Logan, that would be a great place to go; much lower than COS. Also, Provo is an easy airport. |
Marske Flying Wing discussion Group | mat Redsell | Home Built | 0 | September 19th 04 01:58 PM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying Wing Design workshop in july 04 | mat Redsell | Home Built | 1 | May 5th 04 01:53 PM |
restarting instrument flying | Matthew S. Whiting | Instrument Flight Rules | 13 | November 21st 03 01:04 PM |
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan | David Megginson | Instrument Flight Rules | 0 | July 9th 03 03:04 PM |
