#301
Jose wrote: Perhaps you are not familiar with nerf balls. Nerf balls are foam rubber. When a cue ball hits a nerf ball (sufficiently large) nerf ball it stops and the nerf ball just quivers a bit. The center of mas quits moving. The kinetic energy of the cue ball has been converted to heat. Energy is conserved, momentum is not. There is more to that. If this collision occurs in outer space, I guarantee you that the center of mass will =not= quit moving. But it will not move in a manner that conserves momentum. -- FF |
#302
Not until after it passes the high point in the airfoil. Befor it
gets there, it is accelerated upwards. Does the air split (top/bottom path) at the same level as it rejoins? If the air splits at a higher altitude, then the air has to have a net downward motion to get to the rejoin point. When the air reaches the trailing edge it is back to where it started. Is it? I think it's lower than when it started. It certainly is with any appreciable AOA. No, it is a way of looking at downrushing air that has never contacted the wing. It doesn't matter whether it contacts the wing or not. The contact is by proxy (by contacting the other molecules of air that contact...the wing.) You call it pressure. I agree. Pressure is ultimately newtonian; I think we agree there too. It's a floor wax. It's a dessert topping. There is more to that. If this collision occurs in outer space, I guarantee you that the center of mass will =not= quit moving. But it will not move in a manner that conserves momentum. Yes it will. What will not be conserved is macroscopic kinetic energy. Make the room bigger. Make it an infinite room. At what point does the fan continue to put momentum into the air mass continuously, and not just during start up? At the point when it's an infinite room. The bigger the room, the longer it takes for a pressure equilibrium to occur. If we deal with the earth's atmosphere and a propeller, the propeller pushes air back, which alters the rotational momentum of the earth, in a manner equal (and opposite) to the amount of rotational (around the earth's center) momentum the airplane acquires. This could potentially happen until the earth is spinning godawful fast (faster than the propeller could handle). In practice we'll get tired of arguing before that. ![]() So, are you saying that in the presence of the Earth there is no net change in the momentum of the basketballs being thrown by the dribbler and also no net change in momentum of the air molecules accelerated by the wing? Averaged over all basketballs and all air molecules, yes, because the earth acts as a momentum transfer point. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#303
#305
Jose wrote: Not until after it passes the high point in the airfoil. Befor it gets there, it is accelerated upwards. Does the air split (top/bottom path) at the same level as it rejoins? If the air splits at a higher altitude, then the air has to have a net downward motion to get to the rejoin point. Agreed. Clearly this happens with high AOA. When the air reaches the trailing edge it is back to where it started. Is it? I think it's lower than when it started. It certainly is with any appreciable AOA. Are there any airfoils that produce lift at an AOA at or below zero? No, it is a way of looking at downrushing air that has never contacted the wing. It doesn't matter whether it contacts the wing or not. The contact is by proxy (by contacting the other molecules of air that contact...the wing.) You call it pressure. I agree. Pressure is ultimately newtonian; I think we agree there too. But the pressure that supplies the lift is in the air below the wing whereas it is the air above the wing that washes down.You're attributing lift to the wrong air. If he air above the wing washed sideways, and not down at all you'd still get lift as the thumbtack, notecard and soda straw demonstrates. No downwash from the notecard. It's a floor wax. It's a dessert topping. There is more to that. If this collision occurs in outer space, I guarantee you that the center of mass will =not= quit moving. But it will not move in a manner that conserves momentum. Yes it will. What will not be conserved is macroscopic kinetic energy. Right. My mistake. ... So, are you saying that in the presence of the Earth there is no net change in the momentm of the basketballs being thrown by the dribbler and also no net change in momentum of the air molecules accelerated by the wing? Averaged over all basketballs and all air molecules, yes, because the earth acts as a momentum transfer point. -- FF |
#306
I'll tell ya what.
I do admire it. This is the nicest pair of debaters on the planet! Polite. Considerate. Seeem to take time to read, and understand(!) what somebody wrote. Patiently explaining their own position. No yellin. No screamin. No ugly name callin. Archie and Jughead ponder quantum pressure fluctuations. I do love it so... ![]() |
#307
Depends how AOA is defined (I don't know the precise definition). But if we define it as the angle between the line from split to rejoin point, and the direction of travel (or relative wind), then I think not. But the pressure that supplies the lift is in the air below the wing whereas it is the air above the wing that washes down. You're attributing lift to the wrong air. It doesn't matter. The molecules collide all over the place and momentum is moved around (but never lost). If he air above the wing washed sideways, and not down at all you'd still get lift as the thumbtack, notecard and soda straw demonstrates. No downwash from the notecard. Describe the notecard setup better and I will do the experiment, and then tell you what I think. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#308
On Sat, 4 Mar 2006 10:14:36 -0700, "Matt Barrow"
wrote: "Dallas" wrote in message ink.net... "cjcampbell" Actually, he is not. Not in the US, anyway. There is no one by the name of Sagadevan currently holding a pilot certificate of any kind in the US Here he is: http://www.warpaintofthegods.com/wp/about.cfm WOW!! What a fruticake!! Too bad that, or those, mind altering experiences didn't give him a grasp of rationality and reality. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#309
Jose wrote: Are there any airfoils that produce lift at an AOA at or below zero? Depends how AOA is defined (I don't know the precise definition). But if we define it as the angle between the line from split to rejoin point, and the direction of travel (or relative wind), then I think not. ISTR that AOA is defined relative to the chord. But the pressure that supplies the lift is in the air below the wing whereas it is the air above the wing that washes down. You're attributing lift to the wrong air. It doesn't matter. The molecules collide all over the place and momentum is moved around (but never lost). Of course it matters. It is the undisturbed molecules (or minimally disturbed molecules) under the wing that push up on the wing. The air flowing over the top of the wing cannot push UP on the wing. If he air above the wing washed sideways, and not down at all you'd still get lift as the thumbtack, notecard and soda straw demonstrates. No downwash from the notecard. Describe the notecard setup better and I will do the experiment, and then tell you what I think. Take 3 x 5 index card or a similar light small card like a playing card and push a thumbtack through the center. Leave the thumbtack in and set the card on a table point up. Put a soda straw, standing on end over the point of the tack. Blow through the straw and while blowing lift the straw straight up. -- FF |
#310
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 07:23 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
