I saw earlier posts about North Texan's Butterfly and was impressed
with the depth and quality of discussion regarding patents and the limitations and requirements for roadable aricraft. I would welcome your feedback regarding my product: http://www.wolffaerocycle.com/ And an article in the recent issue of Full Throttle (biker rag): http://www.fullthrottlenyne.com/feature2.htm Thanks -Adam |
Ron Wanttaja wrote:
"To invent an airplane is nothing. To build an airplane is something. But to fly is everything." - Otto Lilienthal Ron Wanttaja picky. picky. picky... http://home.earthlink.net/~tp-1/sm-j-01.jpg http://home.earthlink.net/~tp-1/sm-j-02.jpg http://home.earthlink.net/~tp-1/sm-j-04.jpg Sonny Mosel's Fisher Jungster (with extruded aluminum angle fuselage construction ) |
The exposed bike and rider are going to create considerable drag. To
get to reasonable cruise speeds - I'm guessing 100-120 mph or so, to be enough faster than a bike to make it worthwhile - it's going to take a bigger engine than you think. It's going to be difficult to adequately belt the pilot down (in?) if he's sitting on a bike. No IFR, of course, no space for a panel Dealing with 100+ mph wind blast for an extended period is going to be taxing. No reason you can't have a conventional side stick for aileron and elevator. Yes, you have enough degrees of freedom in handlebars, 2 twist grips and 2 grip levers. But it would mean a lot of training to unlearn regular aircraft controls. It comes down to defining your mission. If your goal is to ride your motorcycle through the air, you may have a reasonable answer. If it's to fly somewhere with your motorcycle, I'd lean toward a more conventional airplane that can hoist or ramp a motorcycle inside, and unload at the other end. |
wrote)
I would welcome your feedback regarding my product: http://www.wolffaerocycle.com/ And an article in the recent issue of Full Throttle (biker rag): http://www.fullthrottlenyne.com/feature2.htm Why not revisit the Wright Brothers design - a fitted belt, around the rear tire, up to a big slow turning pusher prop? Just a thought... Montblack I wonder if gyroscopic(?) forces (with the rear spinning tire) would make banking difficult? :-) |
("Montblack" wrote)
And an article in the recent issue of Full Throttle (biker rag): http://www.fullthrottlenyne.com/feature2.htm Why not revisit the Wright Brothers design - a fitted belt, around the rear tire, up to a big slow turning pusher prop? Or: ....a second sprocket or hub - don't use the rear tire. ....a belt/pulley setup, off the engine - like an old tractor. Just a thought... Montblack |
wrote in message ups.com... I saw earlier posts about North Texan's Butterfly and was impressed with the depth and quality of discussion regarding patents and the limitations and requirements for roadable aricraft. I would welcome your feedback regarding my product: http://www.wolffaerocycle.com/ And an article in the recent issue of Full Throttle (biker rag): http://www.fullthrottlenyne.com/feature2.htm Thanks -Adam Usually, the flying car concept is offered as a new, improved way to commute. Wouldn't it be easier to have an airplane that isn't compromised with the unnecessary weight of a motorcycle and position a motorcycle at each end of the commute? The compromises of a flying car (or motorcycle) tend to more or less ruin the craft's utility in one or both roles. |
"Richard Riley" wrote in message oups.com... Snip------- If it's to fly somewhere with your motorcycle, I'd lean toward a more conventional airplane that can hoist or ramp a motorcycle inside, and unload at the other end. A single engine airplane specifically designed to haul a medium weight motorcycle at good cruise speeds seems a very worthwhile thing. I wonder why someone hasn't done it. Bill Daniels |
In article .com,
wrote: Montblack wrote: wrote) I would welcome your feedback regarding my product: http://www.wolffaerocycle.com/ And an article in the recent issue of Full Throttle (biker rag): http://www.fullthrottlenyne.com/feature2.htm Why not revisit the Wright Brothers design - a fitted belt, around the rear tire, up to a big slow turning pusher prop? Just a thought... BMW had (has?) a shaft driven motorcycle. You could have a PTO and clutch that would select between the drive shaft and a belt or chain drive for the prop. Ever seen a shaft-driven bicycle? There were some about 100 years ago. |
("Kyle Boatright" wrote)
[snip] http://www.wolffaerocycle.com/ http://www.fullthrottlenyne.com/feature2.htm Wouldn't it be easier to have an airplane that isn't compromised with the unnecessary weight of a motorcycle and position a motorcycle at each end of the commute? That's great for Point (A) to Point (B) travel ...forgetting, for a moment, about the other (24) letters in the alphabet. Montblack |
| Thread Tools | |
| Display Modes | |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 08:29 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
