Greg Esres wrote:
Sounds like pure speculation to me. Can you support with any FAA material? Doesn't seem speculative to me. The FAA material is the fact that the final approach couse is a DME ARC printed on the approach chart in bold type. A good understanding of approach chart symbology would make that apparent. Also, there are the TERPS: 523. FINAL APPROACH SEGMENT. TACAN and VOR/DME final approaches may be based either on arcs or radials. The final approach begins at a FAF and ends at the MAP. The MAP is always marked with a fix. a. Radial Final Approach. Criteria for the radial final approach are specified in paragraph 513. b. Arc Final Approach. The final approach arc shall be a continuation of the intermediate arc. It shall be specified in NM and tenths thereof. Arcs closer than 7 miles (15 miles for high altitude procedures) and farther than 30 miles from the facility shall NOT be used for final approach. No turns are permitted over the FAF. (1) Alignment. For straight-in approaches, the final approach arc shall pass through the runway threshold when the angle of convergence of the runway centerline and the tangent of the arc does not exceed 15 degrees. When the angle exceeds 15 degrees the final approach arc shall be aligned to pass through the center of the airport and only circling minimums shall be authorized. See Figure |
| Thread Tools | |
| Display Modes | |
| Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 10:32 PM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Partnership Question | Harry Gordon | Owning | 4 | August 17th 03 12:23 AM |
