Ford V-6 engine work
Old August 13th 03, 01:45 PM
Corky Scott
On Wed, 13 Aug 2003 01:58:48 GMT, "Ernesto Sanchez"
Do you have any photos yet?
Ernesto
http://home1.gte.net/res0391z/index.html
There are a few photos in the Christavia Yahoo group. I have a few I
took of cog and flywheel I'll upload today if I can find the time.
Corky Scott
Old August 13th 03, 02:01 PM
Larry Smith
"Corky Scott" wrote in message
On 13 Aug 2003 07:38:50 -0400, Gregg Germain
Hey Croky,
What airplane is this for?
--- Gregg
"Improvise, adapt, overcome."
Smithsonian Center for Astrophysics
Phone: (617) 496-1558
A Christavia Mk4. It's a largish four place high wing monoplane with
STOL
Ahhhh. Swope Farm and Mile Hi Fields beckon.
I'm envious, Corky.
performance. Empty weight is 1350 and gross wt is 2150.
Corky Scott
Old August 13th 03, 02:07 PM
Gregg Germain
Corky Scott wrote:
: On 13 Aug 2003 07:38:50 -0400, Gregg Germain
: wrote:
:Hey Croky,
: What airplane is this for?
:--- Gregg
: "Improvise, adapt, overcome."
:Smithsonian Center for Astrophysics
:Phone: (617) 496-1558
: A Christavia Mk4. It's a largish four place high wing monoplane with
: STOL performance. Empty weight is 1350 and gross wt is 2150.
: Corky Scott
Corky,
Did a goggle search, saw your web page. Very cool. Good luck with
it.
--- Gregg
------------ And now a word from our sponsor ----------------------
For a quality mail server, try SurgeMail, easy to install,
fast, efficient and reliable. Run a million users on a standard
PC running NT or Unix without running out of power, use the best!
---- See
http://netwinsite.com/sponsor/sponsor_surgemail.htm ----
Old August 13th 03, 03:27 PM
Barnyard BOb --
Barnyard BOb -- wrote:
600 ten thousandths
60 thousandths
6 hundredths
.6 tenths....
All the same thing.
When talking about inches, all that stuff you wrote equals 60 mils
which is a heck of a lot easier to say than "60 thousandths of an
inch". Heck, I can't even say the word "thousandths" with any degree
of clarity unless I say it really really slow. There ought to be a
law against such words.
For the record, one mil = 1/1000 of an inch.
And yes, Bob, you are surely correct about the 30 mil overbore and 6
mil piston/cylinder clearance.
David O -- http://www.AirplaneZone.com
Indubitably, Dave, indubitably. 8-)
Barnyard BOb -- Peter Piper picked a peck of pickled peppers
Old August 14th 03, 04:03 AM
Peter Dohm
Larry Smith wrote:
----snip----
I'm envious, Corky.
You're a better man than me. I took a look at the pictures and prose earlier in
the thread. Swope farm didn't look too bad since the 134 foot elevation change
is worth a little more than 50 knots, by my calculation, that the engine need
not contribute; although you'd better be ready when you're ready. On the other
hand, I'd rather just watch mile high from a safe distance; or better yet, not
in "real time".
Peter
Old August 19th 03, 05:10 AM
Bruce A. Frank
Though "thousandths" is the correct word most of the machinists I've
worked with just say "thousands"
Bruce A. Frank
600 ten thousandths
60 thousandths
6 hundredths
.6 tenths....
All the same thing.
Old August 19th 03, 03:06 PM
Model Flyer
"Bruce A. Frank" wrote in message
I've
Oddly I always said, "thow" ie. "30 thow"
Cheers,
Jonathan Lowe
modelflyer at antispam dot net
Antispam trap in place
Bruce A. Frank
600 ten thousandths
60 thousandths
6 hundredths
.6 tenths....
All the same thing.
mils
degree
a
and 6
Old August 21st 03, 02:29 AM
clare @ snyder.on .ca
On Wed, 13 Aug 2003 05:33:03 -0500, Barnyard BOb --
Could you possibly mean...
.028
.030
28 thousandths
30 thousandths
Barnyard BOb --
My apologies. I don't use a micrometer much and every time I do I
have to study and learn it over and over again.
I sympathize, since I did use a micrometer for many years. g
[Got that... big mouth Latchless Larry?]
I meant to say that the cylinders were rough bored to twenty eight
thousandths over, then honed to the final size which incorporated the
sixty thousandths piston clearance.
If that's .060" clearance, then that's what I meant to say.
To throw you another curve....
I'm thinking your piston clearance is really .006 or 6 thousandths.
Clare or Bruce may be chiming in on this one. g
Standard "rule of thumb" for engines you had no specs for was 2 thou
plus 2 thou per inch diameter. Which would be roughly 8 thou.
Camground pistons were usually fitted a bit tighter. Like about half
or less.
Factory spec for a 3.8 is 0.0014 to 0.0028
Old August 21st 03, 02:30 AM
On Tue, 19 Aug 2003 07:23:47 -0400, David O
Yes, in the right context "thousands" sounds like a lazy "thousandths"
anyway. Given my trouble saying "thousandths", I'll have to remember
that.
Every machinist or mechanic I've ever met just calls them Thous.
Old August 21st 03, 12:04 PM
David O
that.
I've heard both used in my somewhat limited exposure to that world.
Now if I started saying "thousandths" or "thous" instead of "mils" in
my professional work (EE, pc board fab, etc), I'd get strange looks
indeed. "Mil" has "of an inch" in the definition which pleases my
engineering sensibilities.
Along similar lines, before "Hertz" was adopted by SI in the late
'60s, most folks just said "kilocycles" instead of "kilocycles per
second". Hertz has "per second" as part of its definition which also
pleases my engineering sensibilities. A lot of hams, however, were
miffed when their beloved "kay cee" was supplanted through a tribute
to a dead German physicist.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
Painting is still tough work Orval Fairbairn Home Built 8 July 23rd 03 04:02 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
