Thank you.
"Allen" wrote in message ... | | "Jim Macklin" wrote in message | news:AAcSf.117626$QW2.38119@dukeread08... | There are no normal pilots, we are all exceptional. | | | Everybody stand and give Jim a high-five! Thank you Jim. | | allen | | |
See if your local library has "Flight of the Gin Fiz" by Henry Kisor.
Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
How can a deaf pilot be aware of radio traffic? I'm a skydiver and have
experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
"Sail-n-Dive" wrote in message ... How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? The same way a Cub, Champ and all the other planes without radios do. There are tens of thousands of airplanes without radios. In a metro area there could be many in the jump area not listening on the frequency the jump plane is using. There is no legal requirement to listen to the jump plane broadcasts. There is a requirement to see and avoid. "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
You do know there is no requirement to have a radio in a plane in most US
airspace. "Sail-n-Dive" wrote in message ... How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
Sail-n-Dive wrote:
How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! This should not happen if the pilot and spotter were checking for traffic before exiting. |
Well, aren't jumps supposed to be announced via NOTAMS? if you are flying NORDO for whatever reason (deaf, antique aircraft without a radio, or radio off as you are perfectly entitled to in uncontrolled airspace), you just avoid the drop zone. Actually I would say that just listening to the radio without being aware of the NOTAMS might not do you much good as you won't really know where the jumpers are anyway. --Sylvain Sail-n-Dive wrote: How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? |
Sylvain wrote: Well, aren't jumps supposed to be announced via NOTAMS? if you are flying NORDO for whatever reason (deaf, antique aircraft without a radio, or radio off as you are perfectly entitled to in uncontrolled airspace), you just avoid the drop zone. Sylvain Problem is sometimes jumps are done impromptu and no NOTAMS filed. In any event, the drop zones are usually published in several places and pilots just do a poor job of pre-flight planning. I've got at least four DZ's within a 40 mile radius of my base but they are active sporadically and mostly on weekends. |
I haven't looked it up in a long time, but DZ need to be
activated before they are used. The PIC of a jump plane should notify the controlling ATC facility before releasing jumpers. Often radar service is available and ATC can advise about traffic in the area. Yep... PART 105-PARACHUTE OPERATIONS -------------------------------------------------------------------------------- Section Contents § 105.1 Applicability. § 105.3 Definitions. § 105.5 General. § 105.7 Use of alcohol and drugs. § 105.9 Inspections. Subpart B-Operating Rules § 105.13 Radio equipment and use requirements. § 105.15 Information required and notice of cancellation or postponement of a parachute operation. § 105.17 Flight visibility and clearance from cloud requirements. § 105.19 Parachute operations between sunset and sunrise. § 105.21 Parachute operations over or into a congested area or an open-air assembly of persons. § 105.23 Parachute operations over or onto airports. § 105.25 Parachute operations in designated airspace. Subpart C-Parachute Equipment and Packing § 105.41 Applicability. § 105.43 Use of single-harness, dual-parachute systems. § 105.45 Use of tandem parachute systems. § 105.47 Use of static lines. § 105.49 Foreign parachutists and equipment. wrote in message oups.com... | | Sylvain wrote: | Well, aren't jumps supposed to be announced via NOTAMS? if you | are flying NORDO for whatever reason (deaf, antique aircraft without | a radio, or radio off as you are perfectly entitled to in uncontrolled | airspace), you just avoid the drop zone. | | Sylvain | Problem is sometimes jumps are done impromptu and no NOTAMS filed. In | any event, the drop zones are usually published in several places and | pilots just do a poor job of pre-flight planning. | I've got at least four DZ's within a 40 mile radius of my base but they | are active sporadically and mostly on weekends. | |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Canadian PPL transition to USA | Jase Vanover | Piloting | 3 | November 27th 05 02:44 AM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
