#11
"Jim Macklin" wrote in message news:AAcSf.117626$QW2.38119@dukeread08... There are no normal pilots, we are all exceptional. Everybody stand and give Jim a high-five! Thank you Jim. allen |
Thank you.
"Allen" wrote in message ... | | "Jim Macklin" wrote in message | news:AAcSf.117626$QW2.38119@dukeread08... | There are no normal pilots, we are all exceptional. | | | Everybody stand and give Jim a high-five! Thank you Jim. | | allen | | |
See if your local library has "Flight of the Gin Fiz" by Henry Kisor.
Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
How can a deaf pilot be aware of radio traffic? I'm a skydiver and have
experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
"Sail-n-Dive" wrote in message ... How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? The same way a Cub, Champ and all the other planes without radios do. There are tens of thousands of airplanes without radios. In a metro area there could be many in the jump area not listening on the frequency the jump plane is using. There is no legal requirement to listen to the jump plane broadcasts. There is a requirement to see and avoid. "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
You do know there is no requirement to have a radio in a plane in most US
airspace. "Sail-n-Dive" wrote in message ... How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? "John T" wrote in message ... See if your local library has "Flight of the Gin Fiz" by Henry Kisor. Henry is a deaf pilot and his book recounts how he learned to fly then retraced the route of Cal Rodgers, who was the first person to fly across the U.S., in 1911. Cal was also deaf. |
Sail-n-Dive wrote:
How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! This should not happen if the pilot and spotter were checking for traffic before exiting. |
For the most part they were average unless you factor in the additional
work it took for them to pass their flight checks and the hassles they did for the medicals. It took some extra effort on my part in learning to adapt their physical problems to the physical acts of control manipulations, etc. It was a challenge and ended up being educational for me as well as fun, and frustrating, and satisfying, and gratifying, etc. Selway Kid |
Well, aren't jumps supposed to be announced via NOTAMS? if you are flying NORDO for whatever reason (deaf, antique aircraft without a radio, or radio off as you are perfectly entitled to in uncontrolled airspace), you just avoid the drop zone. Actually I would say that just listening to the radio without being aware of the NOTAMS might not do you much good as you won't really know where the jumpers are anyway. --Sylvain Sail-n-Dive wrote: How can a deaf pilot be aware of radio traffic? I'm a skydiver and have experienced a plane flying thru a group of decending jumpers both while in freefall and under canopy. This should not happen if the pilot was listening to the radio and knew where they were! The jump plane is required to get permission and to give a warning over the radio before jumpers exit the aircraft. How does a deaf pilot become aware of these and other important messages coming over the radio? |
Sylvain wrote: Well, aren't jumps supposed to be announced via NOTAMS? if you are flying NORDO for whatever reason (deaf, antique aircraft without a radio, or radio off as you are perfectly entitled to in uncontrolled airspace), you just avoid the drop zone. Sylvain Problem is sometimes jumps are done impromptu and no NOTAMS filed. In any event, the drop zones are usually published in several places and pilots just do a poor job of pre-flight planning. I've got at least four DZ's within a 40 mile radius of my base but they are active sporadically and mostly on weekends. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Canadian PPL transition to USA | Jase Vanover | Piloting | 3 | November 27th 05 02:44 AM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
