I've done some testing with regular luan sheets. I find that it doesn't
matter what kind of glue is used if you soak them in regular epoxy (west systems or similar) since the epoxy soaks all the way through. I've boiled test strips for 24 hours with no deterioration. The "West" in West systems stands for "Wood/Epoxy Saturation Technique." It's been used on boats for decades. I use them as core for fiberglass, in place of foam. A bit more weight, but cheaper, stronger, and easier to get. wrote in message ups.com... To All: A 'door skin' is a 3' x 7' sheet of 1/8" Luan plywood. It differs from a regular four-by-eight sheet of eighth-inch luan ply because door skins are USUALLY fabricated using waterproof glue. Snip When properly glued, carefully varnished and religiously maintained, the common door skin has proven to be a trust-worthy material for those of us who are flying on the cheap. -R.S.Hoover |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Flying on the Cheap - Again | [email protected] | Home Built | 9 | January 23rd 05 04:25 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
good and cheap commercial flying school | hananc | Piloting | 1 | October 23rd 03 04:13 PM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
