Benjamin Gawert wrote:
I got an old NARCO LRN-840 LORAN-C that I want to reanimate. Sadly I only got the unit itself, no manuals or cables. What I need is a pinout of the rear card-edge connector and informations about what voltage it requires etc. If someone has a manual as pdf or any other electronic format it would be great if he'd mail that to me. I have an LRN-820, and the pinout may be the same. Looking at the back, top row of pins (L to R) are 1-12; bottom are A-N. GND is H & J (there is no I pin). +14/28v is pin 7. Use a multimeter to verify. GND will be a dead short to the case. Measure +V in to GND: with multimeter set on high resistance, turning switch on should cause the meter to show an increasing resistance reading until an electrolytic capacitor fully charges. Feed in +V thru a 2-3 amp fuse for insurance. Current draw on the 820 is .5A at 14V; .25A at 28V. It probably also requires an amplified antenna. Did you get a little amplifier box which is inserted (near antenna end) in the coax to the antenna? Fred F. |
| Thread Tools | |
| Display Modes | |
| Need help with Narco LORAN LRN 840 | Benjamin Gawert | Owning | 18 | March 29th 06 12:15 AM |
| Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | General Aviation | 0 | January 23rd 04 03:45 AM |
| Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | Aviation Marketplace | 0 | January 23rd 04 03:44 AM |
| Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | Home Built | 0 | January 23rd 04 03:43 AM |
| Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | Products | 0 | January 23rd 04 03:43 AM |
