Quickie / Rutan plans with polyurethane foam
Old March 27th 06, 10:15 PM posted to rec.aviation.homebuilt
Default Quickie / Rutan plans with polyurethane foam
A lot of Rutan planes and derivatives call for polyurethane (in the
fuselage). My understanding is that starting around 1990, builders
have used urethane instead of polyurethane (in Long EZs, etc.). Has
this scenario taken place with Quickie Q1 s... ? Since most Q1s were
built before 1995, would it be safe to say almost all Q1s have
polyurethane...?
Old March 28th 06, 12:11 AM posted to rec.aviation.homebuilt
On 27 Mar 2006 12:15:36 -0800, "
polyurethane...?
To my knowledge all Quckie Q1s were wire cut from Polystyrene foam
billets. Urethane foam cannot be wire cut since it emits a poisonous
gas.
Old March 28th 06, 01:29 AM posted to rec.aviation.homebuilt
polyurethane...?
The canard, wing, vertical tail, and all controls are built using
polystyrene (Styrofoam). The fuselage is urethane foam. The turtle deck does
use some PVC foam there but that is the extent of it. The only changes have
been where the materials come from not how much/where it is being used in
construction.
The Styrofoam is hotwired and the urethanfoam is sanded (if you can call it
that) unless you follow a few surfboard pages and hotwire it. The later
explains why surfers are dieing out. The pvc is bent with a heat gun.
The best and up to date source of information is going to be QBA
http://www.quickiebuilders.org/ and the Q-list on yahoogroups.
http://groups.yahoo.com/group/Q-LIST/
Nemo
Old March 28th 06, 02:04 AM posted to rec.aviation.homebuilt
Later planes - Long EZ's, etc - were largely built with PVC fuselages,
and Styrofoam flying surfaces. Urethane foam and polyurethane foam are
the same thing.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
want to trade 601 plans for 701 plans [email protected] Home Built 0 January 27th 05 08:50 PM
Unused plans question Doc Font Home Built 0 December 8th 04 10:16 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 02:53 PM
