Should I file to an intersection?
Old May 29th 04, 04:33 AM
Slav Inger
Default Should I file to an intersection?
Hi all,
Question: take a look at the VOR Rwy 28 approach at Marshall Brooks
field (RMY). I've filed IFR to airports where the VOR IAF happened to
be the VOR which was no problem, I'd just have that VOR be the last
fix in the route box on flight plan form. In RMY's case, the IAF
appears to be the intersection ALBIO. So, on the flight plan, should
the route terminate at ALBIO? That intersection isn't even on the
enroute chart. Thanks.
P.S. Sorry haven't posted in a while, have had no time to read or
post. Hope y'all are doing well.
- Slav
Old May 29th 04, 04:50 AM
Steven P. McNicoll
"Slav Inger" wrote in message
om...
If the fix isn't on the enroute chart it likely isn't stored in the flight
data processing computer. Filing such a fix in a route will cause the
flight plan to terminate at the previous known fix or be rejected
completely. Just file from the last enroute fix that is on the chart direct
to the field. It's just not that critical.
Old May 29th 04, 05:04 AM
Ron Rosenfeld
On 28 May 2004 19:33:13 -0700, (Slav Inger) wrote:
Hi all,
- Slav
Although it's done in the military (or, at least, it used to be that way),
under Part 91 there is no 'rule' that says you have to file to an IAF.
So I don't pay any particular attention to that procedure. If I am filing
airways, I'd usually file to the last VOR on my route. For example, coming
from my home airport, I'd probably file ...JXN direct. If my computer did
it, the routing would be ...JXN V116 ECKDO direct.
It doesn't really matter. When you get close, ATC will assign an approach
and give you the routing they want you to fly. Or give you radar vectors.
And if you lose communications, they'll protect the IAF airspace anyway.
If I were coming from the South or West, I'd probably file via LFD or BTL
since there are feeder routes from those VOR's to the IAF.
Old May 29th 04, 06:20 AM
Bob Gardner
Your clearance will be to the destination airport, so why no make that the
last entry in the route?
Bob Gardner
om...
Hi all,
- Slav
Old May 29th 04, 02:41 PM
Iain Wilson
Hey Slav, how are ya.
My CFII's IR notes have a bold entry for "Always file to an IAF" and that's
what I do. Not saying this is correct or not, hopefully this thread sorts it
out. Perhaps I haven't come across the situation with an intersection fix
not on the charts in my limited experience.
The whole filing thing is more to do with Lost Comms than anything else.
Unless I've specifically requested the Full Procedure- ABC Transition, then,
as stated by another poster, you always get vectored to final.
Iain
om...
Hi all,
- Slav
Old May 30th 04, 05:22 AM
Richard Kaplan
"Iain Wilson" wrote in message
hlink.net...
In the case of Lost Comm, ATC will try to track your progress either via
transponder or as a primary target. Either way they will be sure the
airspace is cleared to fly any approach at your filed destination.
then,
In many rural or mountainous areas, radar coverage is unavailable and you
must fly complete approaches including published course reversals.
Richard Kaplan, CFII
www.flyimc.com
Old May 30th 04, 05:37 AM
Steven P. McNicoll
"Richard Kaplan" wrote in message
s.com...
Or at any airport along your route.
Old May 30th 04, 09:10 PM
Slav Inger wrote:
Hi all,
- Slav
In this case filing a route to LFD then direct to the airport would be the
best course of action.
Old May 30th 04, 10:13 PM
Snowbird
"Iain Wilson" wrote in message thlink.net...
This is actually an interesting topic.
If you follow Don Brown's interesting columns for AvWeb, a few months
back he emphasized "always file to an IAF". (If you don't follow them
you should).
On the other hand....he also made a statement indicating that he
believed every approach contained an explicit transition from the
Victor airway structure -- IOW, that it's straightforward to include
the transition from the enroute structure to the IAF in your flight
plan. (My paraphrase)
Well, I think that was true once, but enter the RNAV/GPS approach
where (from what I understand) it's considered a transition if an
airway or intersection simply lies in one of the TAA sectors (with
no charted way for ATCS or pilot to readily Get the Picture). And
I know some RNAV/GPS approaches where I don't even think that's true--
certainly not of any VOR or intersection that anyone shooting the
approach would realistically want to fly to, first.
The bottom line is: my obsolete Palm VIIx can hold every VOR, navaid,
intersection, and airport in its measily little memory, but the ATC
computers can't. So if you're planning to shoot a GPS approach,
or if the IAF is not part of the enroute structure and your destination
is served by a different ARTCC than your departure point, there's a
pretty good chance filing to the IAF will only bollix the works.
OTOH, if the IAF is on the enroute charts, if it's an h-class VOR
or an intersection defined by airways, file it.
Mmmm. Well. I have two radios, two antenna, extra headset jacks, and
a handheld radio with headset adaptor. I could be wrong, but I think
the most likely reason for me to lose comms (other than temporarily)
would be electrical failure.
In that case, I think the best thing for me to do is beat it to the
nearest VFR wx.
If I do lose comms for some other reason, I'm going to land at the
nearest practical airport. Let's say I'm flying into BWI. Think
ATC wants me to follow lost comm procs, hold at the IAF for one of
the ILS then shoot the approach? Or do they want me to skedaddle
down the GPS approach into some airport along the way and get out of
their hair ASAP? I know which gets my vote.
Um, no. If you are flying into airports where the ATC facility can
provide radar vectors to the FAC, you almost always get vectored to
final. However, there are many airports and many approaches where this
isn't true, and you'll be flying the full approach including the PT or
other course reversal.
om...
enroute chart.
Slav, if the intersection isn't on the enroute chart, it's not likely
to be in the ATC computers unless your departure is served by the same
ATC facility. So I wouldn't file it.
JMO.
Best,
Sydney
Old June 1st 04, 01:46 PM
Iain Wilson
GPS approaches/Filing IAF
Good to know. You'd think that anything designated as an IAF would be in the
system..
nearest VFR wx.
Undoubtedly, but you still file a plan primarily for routing & lost comms.
If there are no other more sensible actions, then you are supposed to fly
what you've filed.
then,
Um, obviously with no radar, there'll be no vectoring.
om...
enroute chart.
JMO.
Best,
Sydney
How to file XXX to XXX? Nicholas Kliewer Instrument Flight Rules 13 May 19th 04 04:12 AM
Ron Wantaj?? XL file Jerry Wass Home Built 9 March 3rd 04 04:22 AM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 05:55 AM
initial fix an intersection SFM Instrument Flight Rules 14 November 16th 03 12:49 AM
Identifying an intersection with options Ben Jackson Instrument Flight Rules 2 September 3rd 03 06:59 PM
