Vacuum pressure
Old May 30th 04, 03:36 PM
Peter MacPherson
Default Vacuum pressure
At what rpm do people see their vacuum pressure drop below an acceptable
level(3.2?).
I also have a standby vac with a low vac pressure red warning light. When I
reduce power
to 1200-1300 rpm the vac pressure drops off and the red light comes on. I
thought in the
past the pressure would hold until around 1000 rpm. Does this seem to be
working properly?
TIA,
Pete
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 06:17 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 7 November 6th 04 09:34 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 06:49 PM
Vacuum "pressure" for gyros Jari Kaija Home Built 3 March 18th 04 06:08 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
