With the wind?
Old April 5th 06, 12:30 PM posted to rec.aviation,rec.aviation.piloting
Default With the wind?
"Newps" wrote in message
Baloney. If you get a chance go to any big airport on a day with light
winds. Most of these airports have preferred runways, landing in a
particular direction is preferred by the controllers for any number of
reasons. If the wind shifts to make that runway a tailwind, but it's only
5 knots or so, you will land with a tailwind or you will go somewhere
else. Same as my previous example about the crosswind.
Frankly, if a controller tells me I'm to land with a tailwind, he can get
stuffed. Aside from the "hey, that fence is rushing at me quite quickly"
factor, you also have the issue of the extra strain it's putting on the
tyres/landing gear because the ground speed is so much higher.
Generally, of course, the controller will try to accommodate you if you
don't like the "preferred" runway. This happened on my final PPL "skillls
test" - there was a highish (unforecast) crosswind on the east-west runway
by the time, and I wasn't sure whether the examiner would insist I used
that. So I said to him: "Do you want me to use 27, or are you happy for me
to ask for something different?". In hindsight, his reply was obvious:
"You're the pilot, you ask him for whatever you want - even if it means us
diverting". So I asked for RW22 (stiffish breeze only just off the
centreline) and got it.
I've been a passenger in a light aircraft where the controller has insisted
on the PIC using a particular (shortish) runway with a tailwind, though.
Fortunately, the PIC was (a) a 14,000-hour veteran and (b) a stroppy, but
polite old git. The discussion was an interesting one to hear, but the
one-sentence summary goes something like: "You don't have a clue what you're
saying, you don't have the performance documents or POH for this aircraft to
hand, and you're not responsible for the safety of this aircraft; I am,
though, so I'm going to do a visual approach to RWXX instead, and you can
lump it. When we're safely on the ground, if you want to come and argue with
me, that's fine". To the controller's credit, we sat and had a coffee with
him later and both sides explained their point of view in a grown-up manner,
and the controller went away with the understanding that if we'd landed with
the tailwind, we stood a good chance of being in the hedge at the other end.
D.
Old April 5th 06, 11:42 PM posted to rec.aviation,rec.aviation.piloting
stuffed.
That's fine. You land with the flow or you don't land. Your inability
to handle a 5 knot tailwind is not my problem.
factor,
If a 5 knot tailwind does that to you, you are way too fast on final.
Yep, 5 knots. A real tire buster.
Old April 6th 06, 03:22 AM posted to rec.aviation,rec.aviation.piloting
"David Cartwright" wrote in message
So would you go somewhere else or land without a clearance?
insisted on the PIC using a particular (shortish) runway with a tailwind,
though. Fortunately, the PIC was (a) a 14,000-hour veteran and (b) a
stroppy, but polite old git. The discussion was an interesting one to
hear, but the one-sentence summary goes something like: "You don't have a
clue what you're saying, you don't have the performance documents or POH
for this aircraft to hand, and you're not responsible for the safety of
this aircraft; I am, though, so I'm going to do a visual approach to RWXX
instead, and you can lump it. When we're safely on the ground, if you want
to come and argue with me, that's fine". To the controller's credit, we
sat and had a coffee with him later and both sides explained their point
of view in a grown-up manner, and the controller went away with the
understanding that if we'd landed with the tailwind, we stood a good
Did he land without a clearance?
Old April 6th 06, 03:43 AM posted to rec.aviation,rec.aviation.piloting
The PIC can always say UNABLE, a magic word to controllers.
The controller cannot turn the whole airport around at a
busy air carrier airport, there may be dozens of airplanes
in trail for a hundred miles. But the PIC can usually work
something out to get a more favorable runway within a
reasonable time. It helps if you can fly your approach at
higher speeds, nothing like getting a C172 at 62 knots on
final to really slow the airport down.
Don't accept a clearance you can't safely fly, and practice
some non-standard operations to find out how to fly fast and
slow down for the landing.
Most POHs show landing distances with a tailwind, but you
should understand that many pilots fly and land too fast and
waste a lot of runway and have other landing problems [wheel
barrow]. Tires have a speed limit, but that is usually not
a problem on light aircraft.
If you want to fly to a big, busy airport with noise
problems, learn to deal with it.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Steven P. McNicoll" wrote in
message
nk.net...
message
me quite quickly"
putting on the
higher.
clearance?
controller has
with a tailwind,
veteran and (b) a
interesting one to
"You don't have a
documents or POH
for the safety of
approach to RWXX
ground, if you want
away with the
stood a good
Old April 6th 06, 03:47 AM posted to rec.aviation,rec.aviation.piloting
"Jim Macklin" wrote in message
news:3n_Yf.8891$t22.4772@dukeread08...
How so?
Old April 6th 06, 05:15 AM posted to rec.aviation,rec.aviation.piloting
It is an official term, in the pilot/controller glossary
http://www.faa.gov/atpubs/PCG/U.HTM
UNABLE- Indicates inability to comply with a specific
instruction, request, or clearance.
message
k.net...
| "Jim Macklin" wrote
in message
controllers.
| How so?
Old April 6th 06, 01:33 PM posted to rec.aviation,rec.aviation.piloting
news:NJ%Yf.8900$t22.5226@dukeread08...
That makes it a magic word?
Old April 6th 06, 02:34 PM posted to rec.aviation,rec.aviation.piloting
Because ATC can't question you further, you've stated that
you are UNABLE to do whatever it is that they wanted, such
as a turn into a thunderstorm, or a land and hold short. No
need to argue, just say unable and then tell them what you
can do... saves a lot of time.
James H. Macklin
ATP,CFI,A&P
some support
message
ink.net...
| "Jim Macklin" wrote
in message
Old April 6th 06, 05:11 PM posted to rec.aviation,rec.aviation.piloting
It's a metaphor.
Jose
Nothing takes longer than a shortcut.
Old April 7th 06, 12:37 PM posted to rec.aviation,rec.aviation.piloting
nk.net...
No, but the clearance he got that permitted him to do as he wished could be
best described as "begrudging".
D.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Outfly the wind Doug Piloting 7 July 6th 05 04:18 PM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 05:33 AM
