Broken window in jet plane
Old April 11th 06, 12:09 AM posted to rec.aviation.piloting
Default Broken window in jet plane
Hi. I need help with some data. Today, the plane carrying our
country's president had to get back to the aiport because a crack appeared
in a window. This made front page of evening newspapers and stirred up
a heated discussion in local newsgroups.
That said, one of the regulars says a pilot died in a similar
incident in 1998 when a windshield on a 747 fell off and the pilot was
sucked and froze to death. Is it true? I googled a lot and could only find
links to 'Lost' series websites...
Any mythbusters on site?
Eduardo K. | To put a pipe in byte mode,
http://www.carfun.cl | type PIPE_TYPE_BYTE.
http://e.nn.cl | (from the Visual C++ help file.)
Old April 11th 06, 12:23 AM posted to rec.aviation.piloting
no, but there is this story: http://www.gallagher.com/ejection_seat/
"Eduardo K." wrote in message ...
Old April 11th 06, 12:37 AM posted to rec.aviation.piloting
or follow up this
http://www.washtimes.com/business/20...5651-9524r.htm
and this
http://www.airdisaster.com/forums/sh...ad.php?t=72212
".Blueskies." wrote in message
et...
appeared
find
Old April 11th 06, 12:41 AM posted to rec.aviation.piloting
Any "regular" making such a claim should be able to present a record of such
an incident.
I seriously doubt it did happen, but it's a lot harder to prove the absence
of an event. Just because no one here has heard of it, that's not proof it
didn't happen (though it does strongly suggest it didn't ).
If it actually did happen, it should be trivial for someone claiming it did
to show you a news article or aviation agency report describing the event.
I haven't seen the details of the event as originally stated, but your
description doesn't sound plausible to me. There would be significant
airflow through a window, no doubt, but I doubt it would be enough to suck a
person (whatever is meant by that), and freezing to death would require more
than some localized frostbite.
Sounds like your BS detector got set off, and it also sounds like your BS
detector is working properly.
Pete
Old April 11th 06, 01:21 AM posted to rec.aviation.piloting
Not true.
The closest is this
http://en.wikipedia.org/wiki/British...ys_Flight_5390
Old April 11th 06, 01:58 AM posted to rec.aviation.piloting
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dave Doe wrote:
says...
It *did* happen - but guess what, the pilot survived (dunno if it was a
747 though).
The co-pilot did a fantastic job of bringing the plane down to below
10,000' (give the guy hangin' out the window (the captain) a chance!) -
and then landed sucessfully. The captain made a full recovery.
I'm sure someone will dig up the reference.
If I remember correctly, it was a BAe-146. Someone just posted
the link to the incident in the thread. Was a BAW flight.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFEOvFCyBkZmuMZ8L8RAiTyAJ4wEDxnFZ3gOKR2GqSsYe 76am2uNwCggPnP
dYILbPvVGFK7ePRpa8VTATs=
=yd7c
-----END PGP SIGNATURE-----
Old April 11th 06, 04:11 AM posted to rec.aviation.piloting
747 though).
It was actually on Seconds From Disaster on Discover Channel I believe
about 3 months ago. It was pretty interesting. They interviewed the
co-pilot and said the only reason why he told the fight attendant to
hold on to him was in fear of the body being sucked into an engine.
He was sure that the pilot was dead. But when they got on the ground,
they found that the pilot was actually still alive but half frozen.
It was found that the pilot side windscreen had just been replaced and
that the maintenance crew had used the wrong screws which eventually
let loose.
The co-pilot did a good job considering the pilots foot was wedged
into the yoke with the seatbelt.
Scott D.
take out the obvious to email me
Scott D.
Old April 11th 06, 04:58 AM posted to rec.aviation.piloting
There was a case where a mechanic matched new screws from looking at the old
screws, instead of going to the repair book and getting the right screws,
while replacing a windshield in an airliner. The screws he used were
slightly undersized, and they were not able to hold, once they got to a high
pressure differential. On the first (or one of the first) flights, the
windshield blew out. Other pilot, and I think stew, held him from blowing
completely out, but he was most of the way out. I don't remember if he died
or not.
Jim in NC
Old April 11th 06, 05:06 AM posted to rec.aviation.piloting
"Dave Doe" wrote in message
. nz...
says...
appeared
find
747 though).
Duncan, You are thinking of:
http://www.planecrashinfo.com/unusual.htm
06/10/1990
British Airways
BAC-111
On a flight from Birmingham, England to Malaga, Spain, at FL 173, a large
section of windshield fell away from the aircraft. The decompression pulled
the captain out from under his seatbelt. Despite trying to hold onto the
yoke, the captain was sucked out into the opening. A steward in the cockpit
was able to grab hold of his legs. Another steward was able to strap himself
into the vacant seat and aid in holding onto the captain's legs. The copilot
wearing full restraints made an emergency landing at Southampton. The
captain remained half way out of the aircraft for 15 minutes and suffered
only frostbite and some fractures. Improper bolts used to replace the
windshield two days earlier resulted in the accident.
Recovery parachutes again! Cub Driver Piloting 35 July 8th 05 01:47 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 08:27 AM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 01:19 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 08:27 AM
