In article .com,
"Mike" wrote: A finger strap is a reinforcing piece of metal that is used to reinforce a joint. The impression I have is the strap is heated until it can be formed, then wrapped around both the primary and secondary tubing being joined. For both tubes the strap is formed around them. Is the strap tacked in place, then heated until it's plastic, then hammered/tapped/worked so that it is formed around the pieces, or is it somehow formed off of the tubing that's being reinforced? - Mike Tack weld, heat, hammer form when red hot, weld in place. |
| Thread Tools | |
| Display Modes | |
| Crouch Strap story | Ed Byars | Soaring | 43 | September 23rd 13 06:43 PM |
| Finger Pulse Oximeter on Sale | Ray Lovinggood | Soaring | 8 | December 21st 04 04:11 AM |
| Forming Company Veteran Associations | Otis Willie | Naval Aviation | 0 | August 29th 04 06:57 AM |
| Forming Company Veteran Associations | Otis Willie | Military Aviation | 0 | August 29th 04 06:57 AM |
| Discus Battery Straps | Brian Iten | Soaring | 6 | April 8th 04 01:20 AM |
