A friend of mine is building a Legacy and has a question....
Old April 23rd 06, 12:57 AM posted to rec.aviation.homebuilt
Default A friend of mine is building a Legacy and has a question....
On Sat, 22 Apr 2006 08:41:10 -0400, "Peter Dohm"
"Roger" wrote in message
On Fri, 21 Apr 2006 17:32:22 -0500, "Montblack"
wrote)
I have never previously found any use for this knowledge ^h^h^h^h^h^h
opinion.
Hope it is right and helps out.
http://www.familycar.com/Alignment.htm
Had to make sure I had the terms right.
Disclaimer (Don't try this at home)
You could always set about 2 or 3 degrees toe out with a bit of
negative caster. That way the results will be predictable to an almost
certainty and he'll never have a case of bordome on any landing.
As to the toe in, I thought that really was about 2 degrees.
BTW the nose gear on the Deb and Bonanzas has a negative caster. Your
feet are always moving if you plan on even trying to simulate a
straight taxi. That wheel wants to go any where but straight ahead.
www.rogerhalstead.com
Montblack
Roger, I think you mean negative camber. Hilarious nonetheless!
My Bo book calls it caster and it's like trying to push the wheels on
a shopping cart backwards. If you took the linkage off I think it'd
turn right around backwards.
The nose gear strut it tilted forward and a bit to the pilot's side as
well.
Peter
