a couple of questions...
Old April 27th 06, 04:53 AM posted to rec.aviation.piloting
Default a couple of questions...
Also, you can often contact the primary airport while on the
ground at the small field. Depends on the distance and
intervening terrain. Often one of the frequencies, such as
ground or approach will work, you can save a lot of time. A
telephone call before hand will answer the questions about
local procedures. Often if you will be staying within 20-25
miles they will give you a discrete squawk and traffic
advisories the whole time.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Jose" wrote in message
t...
| Also,
| there is a larger commercial airport nearby (still class
E). Of course I
| want to avoid that airport, but what's the best way?
Should I just plot a
| course around it or will they want to vector me?
| (I should have added this to my previous reply.) I would
just plot a
| course around it. They may want to suggest headings to
you, it would
| probably be a good idea to cooperate (though it is not
required). If
| you have two radios, keeping one tuned to the CTAF of that
airport as
| you go by is probably a good idea.
| You can also fly above pattern altitude, say, 1000 feet
above TPA.
| Jose
| The price of freedom is... well... freedom.
| for Email, make the obvious change in the address.
OK, I'm off... Simon Robbins Rotorcraft 15 March 14th 05 01:44 AM
Help me write 25 Aviation Trivia Questions! Jay Honeck Piloting 92 January 17th 04 07:43 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Accelerated spin questions John Harper Aerobatics 7 August 15th 03 08:08 PM
