On 3 May 2006 08:33:30 -0700, "rps" wrote in
.com:: I was close to exchanging paint with a colorful, small plane that approached me from the west and maybe 100 feet lower. It appears that your Near Midair Collision should be reported: http://www.faa.gov/ATpubs/AIM/AIM.pdf 7-6-3. Near Midair Collision Reporting a. Purpose and Data Uses. The primary purpose of the Near Midair Collision (NMAC) Reporting Program is to provide information for use in enhancing the safety and efficiency of the National Airspace System. Data obtained from NMAC reports are used by the FAA to improve the quality of FAA services to users and to develop programs, policies, and procedures aimed at the reduction of NMAC occurrences. All NMAC reports are thoroughly investigated by Flight Standards Facilities in coordination with Air Traffic Facilities. Data from these investigations are transmitted to FAA Headquarters in Washington, DC, where they are compiled and analyzed, and where safety programs and recommendations are developed. b. Definition. A near midair collision is defined as an incident associated with the operation of an aircraft in which a possibility of collision occurs as a result of proximity of less than 500 feet to another aircraft, or a report is received from a pilot or a flight crew member stating that a collision hazard existed between two or more aircraft. c. Reporting Responsibility. It is the responsibility of the pilot and/or flight crew to determine whether a near midair collision did actually occur and, if so, to initiate a NMAC report. Be specific, as ATC will not interpret a casual remark to mean that a NMAC is being reported. The pilot should state “I wish to report a near midair collision.” AIM 2/16/06 7-6-3 Safety, Accident, and Hazard Reports d. Where to File Reports. Pilots and/or flight crew members involved in NMAC occurrences are urged to report each incident immediately: 1. By radio or telephone to the nearest FAA ATC facility or FSS. 2. In writing, in lieu of the above, to the nearest Flight Standards District Office (FSDO). e. Items to be Reported. 1. Date and time (UTC) of incident. 2. Location of incident and altitude. 3. Identification and type of reporting aircraft, aircrew destination, name and home base of pilot. 4. Identification and type of other aircraft, aircrew destination, name and home base of pilot. 5. Type of flight plans; station altimeter setting used. 6. Detailed weather conditions at altitude or flight level. 7. Approximate courses of both aircraft: indicate if one or both aircraft were climbing or descending. 8. Reported separation in distance at first sighting, proximity at closest point horizontally and vertically, and length of time in sight prior to evasive action. 9. Degree of evasive action taken, if any (from both aircraft, if possible). 10. Injuries, if any. f. Investigation. The FSDO in whose area the incident occurred is responsible for the investigation and reporting of NMACs. g. Existing radar, communication, and weather data will be examined in the conduct of the investigation. When possible, all cockpit crew members will be interviewed regarding factors involving the NMAC incident. Air traffic controllers will be interviewed in cases where one or more of the involved aircraft was provided ATC service. Both flight and ATC procedures will be evaluated. When the investigation reveals a violation of an FAA regulation, enforcement action will be pursued. --------------------- § 91.111 Operating near other aircraft. (a) No person may operate an aircraft so close to another aircraft as to create a collision hazard. |
| Thread Tools | |
| Display Modes | |
| Invite A Journalist For A Flight | Larry Dighera | Piloting | 9 | April 28th 06 12:51 AM |
| Southern California airports have worst runway safety records | Larry Dighera | Piloting | 0 | November 26th 05 05:48 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Airports Rated Critical Unsatisfactory: Given Black Star Rating | Michael Ravnitzky | Piloting | 0 | February 3rd 05 04:34 AM |
| fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 10:41 PM |
