charlie foxtrot wrote: Hi All, Yep, one of the b-records in my flight was corrupt, look at the log time, shown with first 6 digits behind the B in line 1 time is 21:12:32 in line 2 time is 22:36:00 in line 3 time is 21:12:40, look at the excerpt of Your IGC file below! B2112323234199N10530479WA0334303580000022015000 B2236003402499N10530538WV0336003583000022015208 B2112403234260N10530608WA0338003602000020015000 The OLC did an administrative validation of my flight - THANK YOU OLC! I received an e-mail suggesting to open the B-record in notepad, and deleting the bogus line. Has anybody else tried this? Chris 'CF' Interesting. I've had 2 club members run into the same problem with the OLC recently. Exact same scenario. Here are the relevant portions of the latest file. Again, it's just one record out of order and, interestingly enough, flagged as a "bad fix". B 170222 4059430N 07500769W A 715 679 B 172206 5904629N 07500719W V 708 681 B 170230 4059510N 07500708W A 700 672 Even more intriguing, in all three files I've looked at, the longitude and altitude portion of the fix suggests that the record is actually a good fix but that the recording is what's screwed up (if you look these values all fit "in sequence" just fine, but the time stamp and lattitude are courrupted). I'm not familiar with the low-level coding in this sort of firmware, but if I didn't know better I'd say there's a very subtle bug in the logging module rather than a receiver problem. BTW, I just import the file into Excel which provides a simple parser at file open. Then, I have some macros to add values such as time between fixes, instantaneous (fix to fix) rate of climb, and rolling average rate of climb (last 6 fixes). Most of the problem show up immediately with this approach. P3 |
| Thread Tools | |
| Display Modes | |
| Missing in Action Serviceman Identified | Otis Willie | Naval Aviation | 0 | March 19th 05 12:58 AM |
| Presidewnt reagan's Missing Man Formation | tony | Piloting | 45 | June 16th 04 12:00 PM |
| missing man formation for Reagan | Paul Hirose | Military Aviation | 1 | June 14th 04 01:50 AM |
| Search for missing plane | C J Campbell | Piloting | 2 | March 4th 04 02:42 AM |
| Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 04:01 AM |
