monitoring pusher props
Old May 16th 06, 05:09 AM posted to rec.aviation.homebuilt
Default monitoring pusher props
"Montblack" wrote in message
("Dave S" wrote)
Just one of the quirks of pushers without a bubble canopy.. hard to tell
if you are on fire.. hard to tell if you are streaming anything... and
hard to tell if the prop is turning.
Speaking of cams ....how 'bout a nanny-cam?
Montblack
My old SeaBee, which IS a pusher, merely mounted a convex mirror out on the
wingtip float. A glance at the mirror and you could check the prop, the
engine compartment drain ( for streaming oil, etc. ) and most of the
tailfeathers. Most of what you saw was water draining off the airframe
after takeoff! :-)
After landing you could see the water on the windshield and didn't need the
mirror! :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
Old May 17th 06, 12:53 AM posted to rec.aviation.homebuilt
"Highflyer" wrote in message
("Dave S" wrote)
tell
Montblack
after takeoff! :-)
mirror! :-)
Highflyer
Come to think of it, I've seen similar mirors on twins, I think Cessna, as
an added verification of the undercarriage. Nice, simple, low tech,
reliable solution. :-)
Peter
Whats the deal with counter-rotating props? Dico Owning 38 February 2nd 06 10:04 PM
Pusher props for WW I fighters John Bailey Military Aviation 3 September 11th 04 11:18 AM
Mil Monitoring in Florida AllanStern Military Aviation 0 April 1st 04 07:18 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 11:20 PM
