Barely reach rudder pedals
Old May 24th 06, 05:26 PM posted to rec.aviation.soaring
Default Barely reach rudder pedals
I apply common pressure when I'm under stress, and one good way to actively
relax in such a situation is to relax the common pressure.
I'd propose that you work on your attitude, rather on changing the rudder
pedals.
"no thanks" wrote in message
Vaughn Simon wrote:
"no thank" wrote in message
I've tried putting less "common mode" pressure
on it, but I don't feel as much in control when I do that. I was
thinking
of installing a wood block to better distribute the force, but I'm
concerned about the safety of that.
Let me guess...you are strictly a glider pilot? That "common mode"
pressure habit I somehow aquired while exclusively flying gliders had to
be lost
quickly when I started flying airplanes. Have you ever made a locked
brake
landing in a Cessna? I did...once.
I am exclusively a glider pilot.
Seriously, your legs are strong and you can apply hundreds of pounds
of
pressure that way without even thinking about it. Have you ever taken a
good
look at how light some of that rudder control rigging is?
I doubt I'm applying more than 50 pounds from each foot, but spread over
an area that is perhaps 2 square inches thats a lot of pressure to be
constantly applying to your foot. I haven't looked carefully at the
assembly, but I doubt I'm stressing it more than its stressing me. Its
not a problem for 45 minutes, but on a multihour flight it gets tiring.
I think part of the issue is seating position. When I'm driving a car, I
don't brace my left foot on the "dead" pedal when not using the clutch. I
assume most planes have more upright seating than the Libelle so I may not
tend to do that as much in a powered aircraft
dan
DG Rudder AD - DONE! - Notes from my work ContestID67 Soaring 0 March 30th 06 08:36 PM
Saitek X-45 and CH Yoke and Rudder pedals wan2fly99 Simulators 0 March 11th 06 02:05 PM
CH Rudder pedals, why don't they work wan2fly99 Simulators 2 January 12th 06 01:30 PM
Information on A310 that lost it's rudder enroute to Canada from Cuba Corky Scott Piloting 3 March 27th 05 04:49 PM
FS2004 tail draggers - no rudder pedals - what do I do?? Hogarth Kramer Simulators 1 August 18th 03 06:43 PM
