Vortex Generator Technicalities, By Peter Garrison
Old May 29th 06, 06:38 PM posted to rec.aviation.homebuilt
Default Vortex Generator Technicalities, By Peter Garrison
cavelamb wrote:
some mindless drivel again...
http://www.home.earthlink.net/~tp-1/a4412-a.jpg
http://www.home.earthlink.net/~tp-1/a4412-b.jpg
Should be working well now.
(-a) shows section drag and moment plotted against section C Lift.
Note that teh moment curve is pretty flat, and has a negative value.
(pitches nose down?)
At the bottom of the page is the Legend.
Curves for 3, 6 and 9 mill Reynolds Number, and with split flaps.
(-b) is a handier form.
Section CL and Pitch moment are shown plotted agains Angle of Attack.
Note that the Flaps Down curve is Narrower and shihted to the left.
Interpret that aa a narrower AoA range, and at a lower AoA values,
but with higher CL/ (delta)Angle ?
(-c) if I had it handy, would be similar to -b, but details the section
Coefficient of Drag.
Old May 29th 06, 09:02 PM posted to rec.aviation.homebuilt
It would work a damn sight better if the images had been created
as gifs or tifs. Then it might be possible to read the labels and
scales.
Jpeg is the worst possible common image format for line drawings
or text. Well, maybe second worst after mpeg...
Don't mean to single you out for this particular rant. Illegible
graphical information is legion on the web. It would seem that
most people posting such haven' t taken into consideration
that people seeing it may actually need to be able to read
the text.
FF
Old May 29th 06, 09:06 PM posted to rec.aviation.homebuilt
Remind me to stand to the RIGHT of that plane when flaps
are down ...
FF
Old May 30th 06, 07:14 PM posted to rec.aviation.homebuilt
"cavelamb" wrote in message
nk.net...
Morgans wrote:
"TJ400" wrote in message
AOA, L/D, Clmax and LE slats are what exactly?.... Been out of the
whole sport aviation for some time and just trying to grasp it all over
snip
I've also noticed that many common airfoils actually have a
_lower_ stall AoA with flaps down!
Like in a 172, notice the way the nose comes down with flaps?
When you lower the flaps, you change the angle of incidence. With a fuselage
that remained level during the change, you would have increased the AoA.
Al
Old May 31st 06, 12:55 AM posted to rec.aviation.homebuilt
scales.
the text.
Point taken, of course.
Totally agree, Fred.
But that's all I got right now...
And I wasn't really trying to pull numbers off of them,
just the shapes of the curves - and how they shift.
Another thing about working with jpg...
Jpg LOSES picture information EACH TIME you SAVE it.
In house, I usually use PCX format.
but these were all I could find...
Rx
are down ...
The meds can sometimes be fun...
Old May 31st 06, 12:57 AM posted to rec.aviation.homebuilt
nk.net...
egroups.com...
snip
Al
True, but we are more concerned with maintaining a given airspeed rather than
a level floor...
Old June 1st 06, 06:25 PM posted to rec.aviation.homebuilt
cavelamb wrote:
nk.net...
egroups.com...
snip
Al
a level floor...
Some pilots are also concerned about having a good view
of the runway.
FF
Peter Igor Andrej Kolar Soaring 1 March 2nd 06 02:32 AM
Visible wingtip vortex! Bill Piloting 23 October 25th 05 10:37 PM
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 03:09 AM
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 09:12 PM
Peter Masak killed in 15 Meter Nationals crash Jim Soaring 14 June 5th 04 04:01 AM
