A. Maxim is very poor on production delivery.
B. Joe Sixpack in East Undershirt Ohio can't go down to the corner Maxim store and buy onesie-twosies on Sunday afternoon. C. One milliampere out of a 25 amp-hour battery will run the battery down in 25,000 hours (1040 days, or a little less than 3 years). If you don't fly your airplane but once in 3 years, that's not my problem. D. Why would you use an unreliable electromechanical device like a relay when a FET is half the price and a thousand times more reliable? Jim "Rob Turk" wrote in message news:Y7_gg.1536$YI3.268@amstwist00... "RST Engineering" wrote in message ... What do you want the cutoff voltage to be? Personally, I'd pick 13.0 volts, but it is child's play to do any voltage you want. There will be about a milliampere of quiescent current for the sensor that will still be on-line when the output shuts off. Jim One-chip solutions designed for this purpose that can detect both undervoltage and overvoltage are available from several vendors, such as Maxim. Example: http://pdfserv.maxim-ic.com/en/ds/MAX6457-MAX6460.pdf These offer very low quiescent current when off (couple of uA). The output can be used to activate a relay (maybe needs an extra transistor). I think you can request free samples. Rob |
... A. Maxim is very poor on production delivery. That's not been my experience, but maybe I've just been lucky. Also, when they offer samples then the chips are available at least in sample quantities. That may not mean much if you want to order 100.000 of them, but for us one-off builders this is fine. Besides, Maxim was just one example. Linear Technologies has similar chips and similar sample programs. B. Joe Sixpack in East Undershirt Ohio can't go down to the corner Maxim store and buy onesie-twosies on Sunday afternoon. The samples ship worldwide. If I can get them easily in Hoevelaken, The Netherlands, Europe then I'm sure they'll ship to East Undershirt Ohio as well. C. One milliampere out of a 25 amp-hour battery will run the battery down in 25,000 hours (1040 days, or a little less than 3 years). If you don't fly your airplane but once in 3 years, that's not my problem. Agree, and if you leave your plane for 3 years without flying I'm sure there will be other issues to worry about.. D. Why would you use an unreliable electromechanical device like a relay when a FET is half the price and a thousand times more reliable? Agree again, it's whatever makes you feel happy. I've had luck with either device. Automotive relays seem pretty reliable, and so are FET's. Jim Rob |
Cessna landing light switch; solved! | jim | Owning | 1 | January 15th 06 10:33 PM |
What does REC mean on the switch? | Jose | Piloting | 10 | June 15th 05 05:55 AM |
C-172 landing light switch | JFLEISC | Piloting | 16 | May 6th 04 01:15 AM |
C-172 landing light switch | JFLEISC | Owning | 10 | May 5th 04 11:05 PM |
Portable Push-To-Talk switch help | Eric Brown | Owning | 9 | April 16th 04 04:26 AM |
