Anyone recognize this fuel cap?
Old June 6th 06, 02:17 PM posted to rec.aviation.homebuilt
Default Anyone recognize this fuel cap?
In a previous article, "Bob Chilcoat" said:
Found on the golf course behind my house (NJ near SMQ).
http://www.geocities.com/viewptmd/P1010001.JPG
http://www.geocities.com/viewptmd/P1010002.JPG
I thought it was probably from a Cessna, but having looked on Ebay, I'm not
sure. Anyone recognize it? What aircraft? I hope he got where he was
going.
Our Cherokees have very similar caps. One time when I was a student
pilot, I went out to the flight line to find the trainer had duct tape
over the filler hole on one tank - somebody had lost the cap, and flown
home with this improvised job, and then not let the flying club know.
I remember that even though it looks like the same cap you could buy for
an old Ford tractor for $4, it cost over $80.
Speaking of tractors, maybe you should check to see if the golf course's
riding mowers use those sort of caps?
Paul Tomblin http://xcski.com/blogs/pt/
If you refer to a woman as any form of waterborne African mammal then a quick
death is absolutely the *best* thing that could happen to you next.
-- Adi
Old June 6th 06, 02:58 PM posted to rec.aviation.homebuilt
It's almost certainly not a Cherokee cap, since it doesn't have the vent
valve, and is quite different from any Cherokee cap I've seen (including the
ones on our Archer). I don't believe it's from a tractor, since it's made
of aluminum.
Bob (Chief Pilot, White Knuckle Airways)
"Paul Tomblin" wrote in message
not
going.
quick
-- Adi
Old June 6th 06, 03:42 PM posted to rec.aviation.homebuilt
I'm betting on the mower--mostly because one of the retaining lugs apears to
be bent. Aluminum is rust resistant and inexpensive to fabricate; and small
things, such as ispection covers, can fall on grass from a considerable
height without damage.
Peter
"Bob Chilcoat" wrote in message
of aluminum.
not
going.
quick
-- Adi
Old June 6th 06, 03:47 PM posted to rec.aviation.homebuilt
On Tue, 6 Jun 2006 13:17:56 +0000 (UTC),
going.
I know of a Cessna 150 with identical caps.
also for the aerodynamics purists the knob sits across the airflow.
Stealth Pilot
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
