Dudley Henriques wrote:
About distraction and the cross check; It's for this exact reason we do the cross check. Distraction is something that every instructor working in the complex environment should be dealing with from the first hour of dual with a pilot moving up into complex aircraft. In fact, it's SO important, it should be treated as a formal step into the complex checkout scenario. The way the instructor handles this single issue will either produce a pilot who has a habit pattern that will stay with him/her the rest of their flying days, or simply one more pilot pushed through the complex checkout stage who is a gear up landing waiting to happen. The role of the complex check pilot is CRITICAL in creating this habit pattern in the pilot being trained. The way it's handled will of course vary from instructor to instructor. I suggest introducing the issue of distraction during the FIRST dual session with a complex transition pilot; first stressing it's existence and dangers in the retract gear environment in the multi-task scenario, then stressing the need for the gear cross check on final. Now this seems normal enough at first glance, and naturally every instructor will do this. But wait........there's more to creating a habit pattern in a pilot then the first step!!!!!!! Usually at this point, this information is simply digested by the trainee as one more thing to remember, but the seed is planted. The next stage is critical. Just planting the seed for a needed habit pattern is not nearly enough, and this unfortunately is where many complex instructors fumble the ball. On EVERY FLIGHT with a complex trainee, before the flight, during the flight, and after the flight, the need for the cross check on final should be RE-INTRODUCED by the instructor. In other words, this single facet of a complex checkout should be repeated on each flight several times. By doing this, the CONSTANT REPETITION of a single item becomes ingrained as a conditioned mental reflex that will function in a distraction environment. Also, one more thing on distraction; The cross check is SO important, and SO critical, that the way it should be taught is that ANYTHING causing a break in the cross check requires a RECHECK of the cross check itself!!. The end result of all this is hopefully a pilot with a highly trained mental trigger concerning his/her final cross check who will be on final and half way through the final pre landing cross check as a distraction occurs. The pilot will AUTOMATICALLY handle the distraction, then REDO the final cross check. If you train yourself to this level of awareness about your final cross check, you should be just fine in the complex environment. One additional thing; your "concern" about making a gear up landing is actually a desired result of proper training for a complex pilot. It's this "concern" that defines the edge that triggers the cross check. So relax......you're perfectly normal!! :-))))))) Dudley Henriques I've been fortunate to have had three instructors (primary, instrument and retractable check-out) who not only taught the above, they gave lots of practice by causing distractions almost all of the time. My instrument instructor was so bad that I flew virtually all training flights with something "not working." The only flight that didn't have a failed instrument was the final prep flight for the check ride. I then began to get distracted wondering why he wasn't introducing any distractions. It was eerie. Matt |
| Thread Tools | |
| Display Modes | |
| Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 30th 05 12:17 AM |
| Would you cycle the gear? | Roy Smith | General Aviation | 41 | April 23rd 04 11:41 PM |
| Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 02:48 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Landing gear door operation | Elliot Wilen | Naval Aviation | 11 | July 7th 03 04:47 PM |
