I know that you have at least two choices.
1- "3M" #8672 2- "Scapa" tape For the first one you need to buy at least 2 rolls at over $250. each. Both are excellent to prevent erosion and abrasion. For example on a floatplane when the prop hit water whe takiing too fast it is like hitting nails so this tape is wonderful. I use the 3M on my wind generators blades and they last forever. www.electrovent.com To be sure that the tape will stick correctly I roll it with a small 2 in. wide wallpaper roller. You cut the tape at 2 in. wide (because the roll is 4 in. wide) and you install half of it (1 in.) on the flat surface of the propeller first and roll it. After you pull gently the remaining one in. on the curved surface of the blade and roll it also. Clean your hands before applying because it will leave fingerprints on the tape and the prop. Even if this tape does not look to stick too much in position, it will stay there. Clean the propeller correctly before to remove any oil or fat. Usually the tape is important on the first 12 inches from the tip of the blade. Bernard PA-12 flyer on floats "Rob Turk" a écrit dans le message de news: EiNjg.2194$YI3.319@amstwist00... "Ian Donaldson" wrote in message ... G'day I have a three blade Warp Drive composite propeller that has clear tape on the tips. The tape needs replacing and I would like to know what I can use as a replacement. Any ideas? We are just about to apply the original tape that comes with the warp drive. I know for sure it's 3M but not which type. I'll see if there's any product numbers on the back and let you know. Rob |
Why does a prop ice up so apparently readily? | Mike Rapoport | General Aviation | 3 | November 8th 05 02:52 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Piloting | 2 | November 8th 05 02:52 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
