Fiberglass vs. Fabric
Old June 17th 06, 05:45 AM posted to rec.aviation.homebuilt
Default Fiberglass vs. Fabric
On 16 Jun 2006 19:57:02 -0700, "Lou" wrote:
Ok, I just finished reading Tony Bingelis's "sportplane builder"
section on covering a wooden plane with fiberglass instead of the
intended fabric. Has anyone in this group ever done this or some who
knows someone who has done this? I'm building a wooden place that
calls for
a fabric covering. I've tried to do as much homework on this subject
as I can but still can not come up with a weight difference between
fabric and a thin coat of fiberglass. I know that the fabric is not
structural so why can't I subsitute a lightweight fiberglass for the
fabric?
Any feedback?
Lou
Lou,The glass that tony referred to is model airplane glass which is
very light and thin. I used it as the outside layer on my leading
edges and tips, however that was over aircraft grade fiberglas not
plywood. Apparently Tony had good luck with it. I think if you did a
Sport Aviation search for Tony's articles on building the Emeraude you
could get a little more information.
Fabric repair D.A.L Home Built 0 April 27th 04 08:17 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 12:37 PM
Fabric Work Doug Home Built 9 January 26th 04 04:31 AM
Need to learn dope and fabric work David Hill Restoration 5 October 9th 03 02:52 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 05:23 AM
