Need help understanding KFC-200 operation
Old June 28th 06, 05:06 PM posted to rec.aviation.ifr
Default Need help understanding KFC-200 operation
My club just got a very nicely equipped Bonanza with a King KFC-200
A/P system installed (along with a CNX-80 GPS). I think I've got most
of it figured out, but yesterday something happend which I didn't
understand.
The active leg in the GPS was a course of about 230, with a stiff wind
from the south. I was about 2.5 miles right of course, and 30 miles
from the next waypoint. I put the course pointer on 230, the heading
bug on 190, and selected FD, HDG, ALT, and AP-ON, and watched the
cross-track error on the GPS; it was decreasing slowly, so I figured I
had a nice shallow intercept angle set up. I then hit the NAV
button. The NAV and ARM lights came on, as expected.
Eventually, Otto intercepted the desired course (as indicated by the
GPS XTE going to zero and the HSI course deviation bar centering.
What I expected to happen at this point was that the HDG and ARM
lights would go out and the CPLD light would come on, and Otto would
start tracking the course. Instead, it just stayed in heading mode
with ARM lit up, slowly taking us left of course. When I recycled the
NAV button, it instantly went into coupled mode and started tracking.
Is my understanding of how ARM/CPLD works in error? Is it possible
that the very shallow intercept angle I had set up (just a couple of
degrees) had somehow fooled the coupling trigger circuitry?
Old June 28th 06, 10:28 PM posted to rec.aviation.ifr
Have you read the POH supplement?
"Roy Smith" wrote in message
King KFC-200
I've got most
didn't
| understand.
a stiff wind
and 30 miles
the heading
watched the
I figured I
NAV
indicated by the
centering.
and ARM
Otto would
heading mode
recycled the
started tracking.
possible
couple of
circuitry?
Old June 28th 06, 11:21 PM posted to rec.aviation.ifr
Yes. Do you think I got this far by just randomly pushing buttons? :-)
Old June 28th 06, 11:32 PM posted to rec.aviation.ifr
If it is, then so is mine - and I've used several different flavors of
KFC autopilots.
Is it possible
Of course it's possible. Neither one of us knows how that circuitry
works, but I can certainly imagine some designs that would be fooled
that way. However, since King keeps those service manuals expensive,
we have no way to find out.
My question is - how far did you let the XTE get in the other direction
before you recycled the NAV button? You might simply not have waited
long enough. All it would take is one comparator out of whack.
Michael
Old June 29th 06, 12:31 AM posted to rec.aviation.ifr
That's usually how I do it.
Old June 29th 06, 12:38 AM posted to rec.aviation.ifr
Roy,
You need to always be sure to give the aircraft a heading
that will actually provide an intercept else it will never go
from ARM to CPLD. Sounds like there is a small offset
in that detector given that you got a couple soon as you
cycled NAV. It is very rate sensitive... it will go to
CPLD when the needle is not nearly centered if the needle is moving
fast
toward the center. If the needle is moving slowly, it will have
to be centered or even a bit past center. The reason is that
the crosswind integrator is only sort of shorted out during
this ARM- capture phase of flight.
When you go to CPLD, the yellow arrow
becomes the course datum.
Note that you can even intercept from FD-APR-ARM mode--wing
leveling only. Heading does not have to be selected to effect the
coupling--but the airplane needs to be aimed so as to
acheive an intercept.
The tip of the day is to always use APR mode when coupling to
your GPS, even enroute. NAV mode is dumbed down
considerably to make crossing over VOR stations less
traumatic. APR doesn't suffer that, and since the GPS
course needle is rock solid APR works great with sharp,
precise coupling. You can fly a T shaped GPS approach
without ever decoupling it-- just feed the new headings in as
cued by the cnx-80.
There's a lot to learn about the KFC-200. Maybe the POH smart-
asses know what it does when the HSI is failed:
answer is that it will either cancel everything or just ignore
the heading bug, depending on how it's wired. Most cancel
everything if heading reference is lost and any mode requiring
heading is selected. But you can turn
FD and ALT modes back on and it will wing-level at a constant
altitude which can be very useful if you are trying to figure
out what to do after a gyro failure. Explore this by pulling
out the HSI breaker.
Have you completely figured out the pitch modes?
Bill Hale BPPP instructor.
understand.
Old June 29th 06, 12:49 AM posted to rec.aviation.ifr
You never know. But in order to capture, the system must be
armed with the CDI a full scale and the intercept angle/rate
must be such that a clear intercept happens. This generally
requires a 30 degree angle. This is from memory, I don't
have the manuals at this time for review.
| "Jim Macklin"
buttons? :-)
Old June 30th 06, 02:55 AM posted to rec.aviation.ifr
That's certainly possible. I didn't let it get very far. Enough that it
was obvious to me that it had gone past center, but less than one dot out
on the HSI. I don't recall what the GPS XTE was, but I'd don't think the
A/P is aware of the XTE directly, just the HSI deviation.
I love playing with this stuff. It makes me feel like I'm back in the
1980's playing with analog computers in the control systems lab :-)
Old June 30th 06, 03:30 AM posted to rec.aviation.ifr
Yeah, it sounds like that's exactly what happened. I'll have to set up the
same scenario again the next time I'm in the plane and let it go a bit
further to see what happens.
That makes sense. The arm/couple circuitry is looking at the deviation
bar. It doesn't know if the bar is moving because you pointed the plane in
the right direction or because the A/P driven by the heading bug did the
same thing. Is suspect you could even get it to go from ARM to CPLD by
moving the course pointer so as to make the deviation bar center.
cued by the cnx-80.
Cool, I'll have to try that. I assume you mean "feed it new courses",
though, right?
I will have to do that too.
You mean the one that suddenly puts the airplane into a 3000 FPM dive?
Yes, I've got that one figured out :-)
But, seriously, I understand altitude hold, and the UP/DOWN rocker switch
doing the 600 FPM climb/descent thing as long as you hold it. I'm still
working on getting the knack the of using CWS to change pitch, and getting
it to fly a coupled ILS, but I think one more flight and I'll have that
nailed.
Old June 30th 06, 04:10 PM posted to rec.aviation.ifr
cued by the cnx-80.
though, right?
Yes that's what I meant. With the yellow d-bar.
nailed.
The easy way to remember this: If the ALT light is OFF, both the
rocker and the CWS button control Pitch ATTitude. Not
specifically
annunciated. When U let up the rocker or cws, the airplane will
hold
the new pitch ATTitude at that moment.
If ALT is ON, both the button and cws hold the new ALTitude
when released. The rocker slews the airplane to a new ALT.
Mostly useful when receiving new altimeter settings
The high taste way of changing altitude is to use the controls in
the ATT
mode, leveling the pitch before engaging ALT. That way there will
be no
altitude dipping or overshooting.
I wrote several articles about this for the ABS magazine as there is
big confusion on these points.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Operation Brother's Keeper preparing for Rita Jim Burns Owning 1 September 23rd 05 01:59 AM
Operation Brother's Keeper preparing for Rita Jim Burns Piloting 1 September 23rd 05 01:59 AM
Trying to Fly AliR Piloting 33 May 9th 05 01:00 AM
