Minimum fuel
Old July 6th 06, 02:27 PM posted to rec.aviation.piloting
Jose[_1_]
Default Minimum fuel
Would you rather be legal and dangerous or illegal and safe? Your choice.
I see your point. However, the question is whether setting a
conservative (fuel) minimum and then deciding for this flight to exceed
it, remaining within FAA rules, does not make one unsafe. Becoming a
test pilot by exceeding aircraft (weight) limitations is more likely to,
IMHO. But each case is different. One can make personal minima as
stringent as one wants (two hour fuel reserve, for example), but the FAA
and the aircraft manufacturers probably do not (the manufacturers want
to market the aircraft's capability, after all)
Not all that is illegal is safe, and not all that is legal is unsafe.
Jose
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 07:13 PM
faith in the fuel delivery infrastructure Chris Hoffmann Piloting 12 April 3rd 04 02:55 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
