![]() "jmk" wrote in message oups.com... Morgans wrote: "jmk" wrote Worst case for most of those RC gyros (designed for RC helicopters, etc.) is about 3 degrees per second. Wow, I didn't know that they sucked THAT bad! g Remember... that's *worst case* according to their spec. They are based on the cheap MEMS solid state chips that are so incredibly cheap because most modern cars have a anywhere from 4 to 20 of them. Usually a couple on each wheel, and another on each wheel that steers. They compensate for the GPS shadowing that is otherwise unacceptable on a moving map when driving in the city or under trees (especially if it's been raining). They are only expected (in this application) to show the basic turn direction for a couple of seconds until the GPS can "catch up." There more critical function is anti-skid, ride quality, and braking functions - again, while the application may be critical, the exact numbers aren't. In a reasonably constant temperature environment, with some minimal compensation from a processor, they should do MUCH better. However, for something like replacing the AH, they are a LONG way from being ready for prime time - at least without major enhancement. [We did some rather fascinating experiments with "shake and bake" when the first uncertified units came onto the homebuilt market. Including putting one on a battery operated record player platter and setting the whole thing (instrumented) in a refrigerator! After a few minutes it showed the plane flying straight and level (DG function) as it went round and round and round... G] Interestingly enough, they are being used as part of the replacement gyro for the King and Sandel HSI. The catch - like the automotive moving map in cars, they are being updated every few seconds by the flux gate. I've been carefully watching the MEMS AHRS and IMU units for a while. The makers claim good performance but charge high prices. There is another way to achieve attitude sensing and that is multi-head GPS receivers that measure carrier phase difference between the antennas. If you combine MEMS AHRS with GPS attitude the two independent systems complement each other such that the AHRS provides "coast-through" attitude during GPS dropouts. It's not cheap but 0.1 degree resolution is possible. Google "CSI Wireless". No connection. bildan |
How about putting three or so of the sensors on board and having them each check the other?
"Bill Daniels" bildan@comcast-dot-net wrote in message . .. "jmk" wrote in message oups.com... Morgans wrote: "jmk" wrote Worst case for most of those RC gyros (designed for RC helicopters, etc.) is about 3 degrees per second. Wow, I didn't know that they sucked THAT bad! g Remember... that's *worst case* according to their spec. They are based on the cheap MEMS solid state chips that are so incredibly cheap because most modern cars have a anywhere from 4 to 20 of them. Usually a couple on each wheel, and another on each wheel that steers. They compensate for the GPS shadowing that is otherwise unacceptable on a moving map when driving in the city or under trees (especially if it's been raining). They are only expected (in this application) to show the basic turn direction for a couple of seconds until the GPS can "catch up." There more critical function is anti-skid, ride quality, and braking functions - again, while the application may be critical, the exact numbers aren't. In a reasonably constant temperature environment, with some minimal compensation from a processor, they should do MUCH better. However, for something like replacing the AH, they are a LONG way from being ready for prime time - at least without major enhancement. [We did some rather fascinating experiments with "shake and bake" when the first uncertified units came onto the homebuilt market. Including putting one on a battery operated record player platter and setting the whole thing (instrumented) in a refrigerator! After a few minutes it showed the plane flying straight and level (DG function) as it went round and round and round... G] Interestingly enough, they are being used as part of the replacement gyro for the King and Sandel HSI. The catch - like the automotive moving map in cars, they are being updated every few seconds by the flux gate. I've been carefully watching the MEMS AHRS and IMU units for a while. The makers claim good performance but charge high prices. There is another way to achieve attitude sensing and that is multi-head GPS receivers that measure carrier phase difference between the antennas. If you combine MEMS AHRS with GPS attitude the two independent systems complement each other such that the AHRS provides "coast-through" attitude during GPS dropouts. It's not cheap but 0.1 degree resolution is possible. Google "CSI Wireless". No connection. bildan |
![]() Bill Daniels wrote: I've been carefully watching the MEMS AHRS and IMU units for a while. The makers claim good performance but charge high prices. There is another way to achieve attitude sensing and that is multi-head GPS receivers that measure carrier phase difference between the antennas. If you combine MEMS AHRS with GPS attitude the two independent systems complement each other such that the AHRS provides "coast-through" attitude during GPS dropouts. It's not cheap but 0.1 degree resolution is possible. There is no question that your idea will work, and work VERY VERY well. NASA did some experiments and the results were WAY better than a conventional AI. Just not quite ready for the consumer market yet - price. But definitely has the potential to become a contender. BTW, ref: the idea of putting multiple units in a "tell me thrice" configuration. That would help, but except for the benefit of redundancy, doesn't gain as much as one would think. They all tend to suffer similar problems. What we did do, which helped quite a bit, was characterize the units over temperature. Although the variation between units is significant (hence the benefits you noted), and the change with temperature is DRASTIC, for any individual unit the change with temperature tends to be quite repeatable. This allows you to temperature compensate the unit with a response curve fit in software. BIG help. Still leaves the inability to differentiate slow drift from a slight deviation from level (or straight). But then a conventional AH (electric or vacuum) has he same problem. |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
A New Air Traffic Control System On The Horizon | Larry Dighera | Piloting | 0 | June 17th 05 03:03 PM |
Air Force Helper 2000 | tomcat | Naval Aviation | 0 | June 9th 04 11:54 PM |
Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 08:10 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
