#31
![]() LJ wrote: Try two hub caps in the shape of a frizz-be(sp).Cut a hole in one cap and weld it to the top of your exhaust pipe,weld the other cap one or two inches above the first cap.You won't hear the exhaust. That sounds very interesting. But I'm having trouble reconciling "two hubcaps in the shape of a frisbee." with the second one welded "one or two inches" above the first. Do you mean like this: ___ / \ (gap) \ _ _ / | | | | (This will look beter with a non-proportionate font.) -- FF' |
#32
#33
![]() "john smith" wrote in message ... Sine wave, square wave and things inbetween. It's all about the "area under the curve". Tim "The Tool Man" Taylor always wanted "more power". Sometimes, this is not a good thing. The "power" delivered by cycle, be it square wave, sine wave or things inbetween, can be found by calculating the area under the curve. For a square wave, it is simple the width times the height. That is why I asked about the wave form. I was assured it was sine wave. I still wonder. Usually they are proud of true sine wave, and advertise it. -- Jim in NC |
#34
![]() "Lou" wrote in message ups.com... Jim, too bad you can't hear my applause. That was such a good explination, I even understood it. Thanks Thanks. After all I am supposed to be a teacher! :-)) -- Jim in NC |
#35
![]() "john smith" wrote Sine wave, square wave and things inbetween. It's all about the "area under the curve". There are methods to reduce the area above the sign wave within the square wave, but they complicate the inverter design and can add volume to the packaging. snip Pulsewidth modulation, an electronic means of making different length square waves is an elegant solution, but adds cost and complexity. snip The Yamaha is supposed to have pulse width modulation, which if it is fast enough, can come pretty close to sine wave, I guess. -- Jim in NC |
#36
"Morgans" wrote: The Yamaha is supposed to have pulse width modulation, which if it is fast enough, can come pretty close to sine wave, I guess. Powerwise, yes. As a sinewave arcs up to a peak then arcs down, the pulse widths become progressively wider then narrower. The average of the area under the curve approaches the power of of the sinewaveform. A simplified approximation... _ __ ___ __ _ | | | | | | | | | | _| |_| |_| |_| |_| |_ |
#37
![]() "Morgans" wrote in message ... That is why I asked about the wave form. I was assured it was sine wave. I still wonder. Usually they are proud of true sine wave, and advertise it. From the Yamaha site: " a.. Inverter System with Pulse Width Modulation - Industry-leading system produces higher-quality and cleaner electricity. Results in pure sine wave as clean or cleaner than commercial power and can operate products with built in microcomputers." a.. Note the words: " Results in pure sine wave". Yes, it is pwm (just like any sine wave inverter I know of), but the resultant waveform is far cleaner than you will get from most any other generator, particularly from any other consumer grade generator. If you look closely at the specifications & instructions that come with cheap generators, you will often see verbage warning you about operating sensitive equipment. This is because they can have distorted waveforms, off-frequency operation, and poor voltage regulation. (That said, they often manage to do the job amazingly well.) This conversation started about refrigeration motors which can be quite fussy about waveform, but it is little understood that modern electronics have switching power supplies that can be pretty insensitive to waveform. Strangely, your computer is more likely to run well off of your cheap inverter than your refrigerator, even though both of them may require about the same wattage. Vaughn -- Jim in NC |
#38
In article
, "Vaughn Simon" wrote: This conversation started about refrigeration motors which can be quite fussy about waveform, but it is little understood that modern electronics have switching power supplies that can be pretty insensitive to waveform. Strangely, your computer is more likely to run well off of your cheap inverter than your refrigerator, even though both of them may require about the same wattage. (I am trying to remember all this from college physics) Think about how a refridgeration system "starts" and runs. There is usually a "start-run" capacitor. The capacitor is a "voltage" device. The motor to run the compressor is a "current" device. ELI ICE Voltage leads current in an inductor (motor) by 90-degrees Current leads voltage in a capacitor by 90-degrees This has to do with the current and voltage phase with respect to each other. This is really neat to watch on an oscilliscope. Draw a picture of two sinewaves, shifted by 1/4-wavelength. As you start up the compressor, the motor draws a slug of current, so the sinewave current waveform distorts to look something like a sharks fin. As the current gets sucked into the wires of the inductor, the voltage collapses. The start-run capacitor dumps its stored voltage to hold the line voltage up until the current draw diminishes as the magnetic field is established. Then the capacitor draws a slug of voltage to recharge itself, and the voltage waveform takes on the sharkfin shape. And then the process repeats itself. (Does that sound right to the experts out there?) |
