barrel roll in 172
  #11
Old July 20th 06, 09:31 PM posted to rec.aviation.piloting
Jim Macklin
Default barrel roll in 172
The issue is recovery from a botched barrel roll, such as in
inverted stall followed by a high speed dive and too strong
a pull on recovery.
"Big John" wrote in message
| Andrey
| As has been said in all the posts, the short answer is NO.
172 is not
| certified to do barrel rolls.
| However I can barrel roll a 172 only pulling 1 G which
puts no more
| load on airframe than straight and level flight. I have
thousands of
| hours to back up my statement.
| A corollary.
| Is a 707 certified for barrel rolls? Short answer is NO.
| Did a Boeing Test Pilot barrel barrel roll a 707 over the
boat races
| on Lake Washington without any damage to aircraft. YES.
| I'm also sure Dudley can barrel roll the 172 without any
problem or
| exceeding any limits.
| Long Long answer is don't try to B-roll the 172.
| My 1971 172/Skyhawk Owneers manual shows:
| Normal Cateory Maneuvers
| Max pos G' = 3.8
| Stalls and turns not to exceed 60 degrees of bank.
| Utility Caategory Maneuvers
| Max pos G's = 4.4
| Chandelles
| Lazy Eights
| Steep Turns
| Spins
| Stalls (Except whip stalls)
| Acrobatics that may impose high loads should not be
attempted.
| Big John
| On 20 Jul 2006 04:34:44 GMT, Andrey Serbinenko
| wrote:
| If kept within the normal category load limits, is 172
certified to do
| barrel rolls?
| Andrey
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 09:27 AM
