#121
Andrey Serbinenko wrote: If kept within the normal category load limits, is 172 certified to do barrel rolls? Andrey No, but you can do a slip-short split-S if you so desire. I've only done one in a low wing, but keeping positive 1g throughout is necessary. They don't have the roll rate of an edge 540 so I don't know why you would even want to do anything like a barrel roll in a training aircraft. I like your live on the edge spirit though!! |
#122
(5) Model 172L (1972 model)
"This airplane must be operated in compliance with the operating limitations as stated in the form of placards, markings, and manuals: MAXIMUMS Normal Category Utility Category Maneuvering speed (CAS) 122 mph (106 knots) 122 mph (106 knots) Gross weight 2300 lbs. 2000 lbs. Flight load factor Flaps up +3.8 -1.52 +4.4 -1.76 Flaps down +3.5 +3.5 Normal category - No acrobatic maneuvers including spins approved Utility category - Baggage compartment and rear seat must not be occupied. No acrobatic maneuvers approved except those listed below. Maneuver Max. Entry speed Chandelles 122 mph (106 knots) Lazy eights 122 mph (106 knots) Steep turns 122 mph (106 knots) Spins Slow deceleration Stalls (except whip stalls) Slow deceleration" Spin recovery: opposite rudder - forward elevator - neutralize controls. Intentional spins with flaps extended are prohibited. Known icing conditions to be avoided. This airplane is certified for the following flight operations as of date of original airworthiness certificate: (DAY NIGHT VFR IFR)" (as applicable) Download the entire TCDS here http://www.airweb.faa.gov/Regulatory...4?OpenDocument "JerryGirrafe" wrote in message ups.com... | | Andrey Serbinenko wrote: | If kept within the normal category load limits, is 172 certified to do | barrel rolls? | | Andrey | | No, but you can do a slip-short split-S if you so desire. I've only | done one in a low wing, but keeping positive 1g throughout is | necessary. They don't have the roll rate of an edge 540 so I don't know | why you would even want to do anything like a barrel roll in a training | aircraft. I like your live on the edge spirit though!! | |
#123
Jim Macklin wrote
(5) Model 172L (1972 model) "This airplane must be operated in compliance with the operating limitations as stated in the form of placards, markings, and manuals: Yeah Jim, and we all MUST comply with all highway speed limits, even when they were 55 mph. Hell...my speedometer even had a big red mark at 55 mph. A lot of those placards, markings, and manual limits are just because the manufacturer did not want to spend the time and money in order to seek certification for a particular item. Such is the case of the "no slips with flaps" contained in the manual for a lot of the C-172s. Bob Moore |
#124
On Tue, 01 Aug 2006 11:57:10 GMT, Bob Moore
wrote in :: A lot of those placards, markings, and manual limits are just because the manufacturer did not want to spend the time and money in order to seek certification for a particular item. Such is the case of the "no slips with flaps" contained in the manual for a lot of the C-172s. From: (Jackie Murray) Newsgroups: rec.aviation.piloting Subject: Cessna 172 slips with flaps Date: 5 Jul 1994 15:06:35 -0400 Message-ID: NNTP-Posting-Host: 141.114.130.70 I know this has been beaten to death, but I just received an article from AOPA about the C172 and there is a reference to this problem. Article: "Anatomy of a Success" (The makings of a winner) by Thomas A. Horne, AOPA Pilot in May, 1992. In describing the phenomenal success and popularity of this plane when introduced in 1955, the author says this: "There was -- and still is -- one handling quirk: In a forward slip with flaps extended, a 172 could pitch nose down, violently enough to push a pilot against his seat belt. This is caused by an upturned aileron's reducing the normally strong downwash of air over the horizontal tail. Though puzzling in its infrequency, Cessna saw the potential for trouble. Consequently, a placard is installed near the flap control: Avoid slips with flaps extended." Message-ID: An added note in this article...I am still reading it....in 1972 the 'dorsal fin was extended all the way forward to the rear window. This helped virtually eliminate the nose-down pitch problem in sideslips and made the airplane much more spin resistant....Cessna received complaints from some flight instructors because of this characteristic. Demonstrations of fully developed (three-turn) spins were difficult to perform; result was usually a spiral" |
#125
Cessna received
complaints from some flight instructors because of this characteristic. Demonstrations of fully developed (three-turn) spins were difficult to perform; result was usually a spiral" Interesting. Cessna creates a safer airplane, and people complain. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#126
Larry Dighera wrote
I know this has been beaten to death, but I just received an article from AOPA about the C172 and there is a reference to this problem. Article: "Anatomy of a Success" (The makings of a winner) by Thomas A. Horne, AOPA Pilot in May, 1992. What makes the AOPA or Thomas Horne an authority on the subject? I have posted the following on previous occassions before and still believe it to be true. It is excerpted from the book, "Cessna, Wings for the World" by William Thompson. Bill Thompson served as Manager of Flight Test and Aerodynamics for the Cessna Aircraft Company. Seems as if he should know the 'real' story. Bob Moore With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher- powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed. |
#127
On Tue, 01 Aug 2006 16:01:39 GMT, Bob Moore
wrote in : : I just received an article from AOPA about the C172 and there is a reference to this problem. Article: "Anatomy of a Success" (The makings of a winner) by Thomas A. Horne, AOPA Pilot in May, 1992. What makes the AOPA or Thomas Horne an authority on the subject? It sounds like he just paraphrased the quote you posted. I have posted the following on previous occassions before and still believe it to be true. It is excerpted from the book, "Cessna, Wings for the World" by William Thompson. Bill Thompson served as Manager of Flight Test and Aerodynamics for the Cessna Aircraft Company. Seems as if he should know the 'real' story. Bob Moore With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher- powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed. |
#128
People were beginning to talk about all the different
maneuver that can be done in an airplane [in this case the 172, but this applies to all airplanes]. The OP asked about "normal category" but even allowing for utility category, the 172 is approved for very limited aerobatics. The specific allowed maneuvers are listed. Certainly, any airplane can perform any aerobatic maneuver, since all the controls are present for all axis. But just as any camera can take portraits or porn, any airplane will only do what the pilot can do. If your name is Bob Hoover et al, you don't need to ask the question and you probably can do these maneuvers. But Joe Sixpack is going to do several things...(a) bend the airplane (b) break the airplane (c) wish he had a quick jettison door (d) wish he had a parachute and (e) die. Simple rule, The Law of Gravity has no exceptions or appeals. -- James H. Macklin ATP,CFI,A&P "Bob Moore" wrote in message . 121... | Jim Macklin wrote | | (5) Model 172L (1972 model) | "This airplane must be operated in compliance with the | operating limitations as stated in the form of placards, | markings, and manuals: | | Yeah Jim, and we all MUST comply with all highway speed limits, | even when they were 55 mph. Hell...my speedometer even had a | big red mark at 55 mph. | | A lot of those placards, markings, and manual limits are just | because the manufacturer did not want to spend the time and | money in order to seek certification for a particular item. | | Such is the case of the "no slips with flaps" contained in the | manual for a lot of the C-172s. | | Bob Moore |
#129
since all the controls are present for all axis. But just as any camera can take portraits or porn Certainly not. Not all airplanes have sufficient control authority to perform all aerobatic maneuvers, and not all cameras can take macros. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#130
You have to have "macros" to take porn? "Any acrobatic
maneuver" wasn't intended to mean 720 degree roll per second rate or tail slides, or but just the basic 3 axis and combinations. "Jose" wrote in message . .. | Certainly, any airplane can perform any aerobatic maneuver, | since all the controls are present for all axis. | | But just as any camera can take portraits or porn | | Certainly not. Not all airplanes have sufficient control authority to | perform all aerobatic maneuvers, and not all cameras can take macros. | | Jose | -- | The monkey turns the crank and thinks he's making the music. | for Email, make the obvious change in the address. |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
