ET wrote:
The Zodiac is a great little plane, it was on my short list of 2 of planes to build. It's still on my short list. What was the other plane on your short list, if you don't mind my asking? but it has never met it's advertized speeds (go to the matronics Zodiac list and read the archives of posts of Zodiac builders if you dont believe me) Actually I've researched the written material on the Internet regarding the Zodiac and unless I missed something, those complaints refer to older 601 models. I haven't seen any complaints regarding the Zodiac model making its rated speed, which I believe has redesigned wings. I haven't ordered the Kitplane's January 2004 issue to see what the article "Zenith vs. Zenith Showdown (Zodiac 601 XL - Stol CH 701)" said about it meeting its claimed speed. Unfortunately the usefulness of Matronics postings is about on a par with the usefulness of Usenet postings - at best merely suggestive, but they always need more authoritative confirmation. |
Jim Logajan wrote in
: ET wrote: The Zodiac is a great little plane, it was on my short list of 2 of planes to build. It's still on my short list. What was the other plane on your short list, if you don't mind my asking? but it has never met it's advertized speeds (go to the matronics Zodiac list and read the archives of posts of Zodiac builders if you dont believe me) Actually I've researched the written material on the Internet regarding the Zodiac and unless I missed something, those complaints refer to older 601 models. I haven't seen any complaints regarding the Zodiac model making its rated speed, which I believe has redesigned wings. I haven't ordered the Kitplane's January 2004 issue to see what the article "Zenith vs. Zenith Showdown (Zodiac 601 XL - Stol CH 701)" said about it meeting its claimed speed. Unfortunately the usefulness of Matronics postings is about on a par with the usefulness of Usenet postings - at best merely suggestive, but they always need more authoritative confirmation. I disagree about the Matronics postings, most are from actual builders building real planes using their own name and most times having a personal website showing construction, etc. to back up claims of being a builder. I have read several posts from builders of the XL claiming substantially reduced cruise speeds off of the MFR claimed numbers. My other choice was the Sonex, I chose the Sonex, & I chose to scratch build. I started last September and now have all the angle and plate parts built, one wing built, both the spars built, and the empenange built. I'm starting the other wing now and all of the major parts are built, starting actual assembly. The Sonex plans are second to none for a scratch builder. Every single piece that could be depicted full size on the 24"X36" plans is shown full size. Every single rivet & bolt is called out, there is no guessing or using "accepted practices" The Zenith plans are adiquate for a kit builder and lacking for a scratch builder, although I know many have been scratch built sucessfully. I chose the Sonex for 1) Quality of Plans 2) Cost 3) speed-every post I've read from Sonex builders claim the plane lives up to the factory speeds. The only downside to the Sonex is it may be a bit small in the cabin for a really big guy (or 2). I'm 5'10" & 195 & fit great. Try to find one to sit in before you decide for certain (same for the Zodiac for that matter). Not trying to dis the Zodiac too much here, if the Sonex did not exist I'd be building a Zodiac XL. BTW the Sonex also has a very active email list at groups.yahoo.com\SonexTalk -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
![]() "ET" wrote in message ... Jim Logajan wrote in : ET wrote: The Zodiac is a great little plane, it was on my short list of 2 of planes to build. It's still on my short list. What was the other plane on your short list, if you don't mind my asking? but it has never met it's advertized speeds (go to the matronics Zodiac list and read the archives of posts of Zodiac builders if you dont believe me) Actually I've researched the written material on the Internet regarding the Zodiac and unless I missed something, those complaints refer to older 601 models. I haven't seen any complaints regarding the Zodiac model making its rated speed, which I believe has redesigned wings. I haven't ordered the Kitplane's January 2004 issue to see what the article "Zenith vs. Zenith Showdown (Zodiac 601 XL - Stol CH 701)" said about it meeting its claimed speed. Unfortunately the usefulness of Matronics postings is about on a par with the usefulness of Usenet postings - at best merely suggestive, but they always need more authoritative confirmation. I disagree about the Matronics postings, most are from actual builders building real planes using their own name and most times having a personal website showing construction, etc. to back up claims of being a builder. I have read several posts from builders of the XL claiming substantially reduced cruise speeds off of the MFR claimed numbers. My other choice was the Sonex, I chose the Sonex, & I chose to scratch build. I started last September and now have all the angle and plate parts built, one wing built, both the spars built, and the empenange built. I'm starting the other wing now and all of the major parts are built, starting actual assembly. The Sonex plans are second to none for a scratch builder. Every single piece that could be depicted full size on the 24"X36" plans is shown full size. Every single rivet & bolt is called out, there is no guessing or using "accepted practices" The Zenith plans are adiquate for a kit builder and lacking for a scratch builder, although I know many have been scratch built sucessfully. I chose the Sonex for 1) Quality of Plans 2) Cost 3) speed-every post I've read from Sonex builders claim the plane lives up to the factory speeds. The only downside to the Sonex is it may be a bit small in the cabin for a really big guy (or 2). I'm 5'10" & 195 & fit great. Try to find one to sit in before you decide for certain (same for the Zodiac for that matter). Not trying to dis the Zodiac too much here, if the Sonex did not exist I'd be building a Zodiac XL. BTW the Sonex also has a very active email list at There are so many engine/prop/cowling combos that MFG numbers mean diddly. It seems that with a the right prop setting William Wynne's XL might actually be faster than the Zenith numbers and faster than the LSA rules permit. I flew in the factory 601XL with a Jabiru engine and it was meeting factory numbers. As far as match drilled holes matching up I can't say much. When I bought my kit the only pre-drilling was on the wing skins and they matched up perfectly with the undrilled ribs that were installed in keeping with the plans. There were some early problems when they first started the match drilling in more places but from what I understand the kits shipping now don't have that problem. |
Oshkosh Reflections | Jay Honeck | Home Built | 54 | August 16th 05 09:24 PM |
Oshkosh Reflections | Jay Honeck | Owning | 44 | August 7th 05 02:31 PM |
Oshkosh Reflections | Jay Honeck | Piloting | 45 | August 7th 05 02:31 PM |
Oshkosh EAA Warbirds ??? | Paul | Restoration | 0 | July 11th 04 04:17 AM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
