EW B-Model flight recorder
Old August 16th 06, 07:35 AM posted to rec.aviation.soaring
Pete Brown
Default EW B-Model flight recorder
EW Baro Start Up Procedure
Press ON
"FREE" flashes and then a number indicating % of memory
remaining appears
Press ENT
"CLEr" flashes
Press NO (unless you need to clear memory for flight)
year appears. If incorrect, enter last 2 digits of year
Pres ENT
mm/dd appears. If incorrect, enter 4 digits
Pres ENT
time appears. If incorrect, enter time in hhmm 24 hrs format
Pres ENT
U (user number) appears. Enter number from 1 to 9999 to
identity pilot, aircraft, or observer. 7 is default for Pete
Brown
Pres ENT
INT (interval will momentarily appear.) Enter [10] seconds.
Pres ENT
Baro will now start flashing, recording PA( pressure
altitude) at 10 second intervals.
To Begin Calibration Process: (see page 30 of manual)
Press [ENT] [4] [ENT]
Reads in thousands of meters, i.e., .120 = 120 meters
Baro should now be placed in decompression chamber with
display facing operator and decompressed normally. Chart is
made of chamber readings and baro display reading.
To turn off
Press [ON] [OFF] [OFF]
Common Error codes
Err2 memory low but useable 3.3 hrs at 10 second sample rate
Err5 battery is low, change soon, several hours remain
Err6 device has turned off due to extremely low battery
Use 10 second sample rate for badges & records
10 seconds = 10 hours of data
30 seconds = 30 hours
Battery: PP3 alkaline 9 volt
To check battery level
Press [ON] [3] [time]
fresh battery should be ~500
replace at ~ 350
do not use below 300
I have a manunual that I could copy. Email me for details on
where to send it if you would like.
Pete Brown pdbatgcidotnet
BDS
I have an old EW B model flight recorder with no manual. Is anyone familiar
with this device willing to post a quick list of the keyboard functions?
I have figured out the basics and can get it to record from my GPS - I just
want to know how to access all of the functions, or as many as someone might
be willing to spend the time typing out.
BDS
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 07:31 PM
Stupid Question Crash Lander Piloting 35 July 23rd 06 03:39 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
