primary flight instruments on partial panel
Old August 25th 06, 06:35 AM posted to rec.aviation.ifr
Jim Macklin
Default primary flight instruments on partial panel
I'm speaking of the question by the OP, which seemed to be
asking if all you had was the compass or the TC [needle],
which would be primary.
The compass gives 0 [zero] bank angle indication and in a
steep turn may not rotate at all. Controlling the airplane
can be done with the TC plus some pitch instrument.
Controlling the airplane with ONLY the compass is much more
difficult because it indicates reverse turn direction on all
headings except near 180 degrees (northern hemisphere).
Very few airplanes have the mag compass located where it can
be flown as sole reference, most are mounted on the
windshield post.
James H. Macklin
ATP,CFI,A&P
| Jim Macklin wrote:
| If you're down to just the compass, worry more about
keeping
| the wings "level" and less about heading. The compass,
in
| the northern hemisphere will work as the sole instrument
| only when flying south [saw between 150-210] heading.
It
| will be very sensitive and indicate the correct turn
| direction.
| I'm not sure I follow. During my CFII training I got a
solid 2 hours of
| flying partial panel with compass turns. I was able to fly
exact
| vectors to ILS, etc. If I was off even by 2 degrees when I
rolled out
| on a heading my CFII would yell at me. I can tell you from
experience
| you 100% can fly very, very exact headings in any
direction using
| compass turns if you know how to read the compass and
account for the
| effects. I'm not saying doing so in IMC would be as easy
as it is under
| the hood but personally, I would do that in a second
before trying to
| do the math required of timed turns while under the
pressure of partial
| panel IMC. Of course most of us have GPSs which are
actually a much
| better partial panel way to figuring heading (approximated
as course).
| -Robert, CFII
Old August 25th 06, 01:05 PM posted to rec.aviation.ifr
David Cartwright
"Greg" wrote in message
In primary and supporting method of attitude instrument flying, which
do you consider the primary instrument for bank in the partial panel
situation (loss of both attitude indicator and heading indicator)?
Turn coordinator or magnetic compass?
The turn co-ordinator is your primary measure of bank, for a couple of
reasons. First, the compass doesn't measure bank angle - it just shows what
direction you're pointing in - whereas the TC does show the degree to which
you're banked. Second, and most importantly, because of the way it's put
together, the compass doesn't turn steadily, and so it'd be wrong to fool
yourself into thinking that the faster the compass was moving, the more
you're banked.
Have a go one day and you'll see. Take someone competent with you to look
out of the window, get to a safe place and height, make sure your DI's set
correctly, and do a rate-one turn through 720 degrees or more (go around as
much as you like, in fact). In the northern hemisphere at least, you'll note
that when the DI goes through 090 or 270, the compass stands a fair chance
of agreeing with the DI. As you go through north, though, the compass will
under-read, and as you go through south, it'll over-read. The only time you
can rely on the compass is when going in a straight line - which is why you
always check and adjust your DI when flying in a straight line.
Hence if you want to do a partial-panel turn in IMC, you fly straight and
check the compass, then do a rate-one turn (the turn co-ordinator shows you
the bank angle) for the required number of seconds - three degrees per
second for a rate-one turn, of course. You then level out, give the compass
a few seconds to stop wiggling, and then adjust your heading if you're a
little bit out. I seem to recall in the IMC rating test you have to get to
within five or ten degrees of the desired heading with one initial turn and
one "fine tune" adjustment - which is generally pretty achievable.
David C
Old August 25th 06, 03:43 PM posted to rec.aviation.ifr
Allen[_1_]
"David Cartwright" wrote in message
what direction you're pointing in - whereas the TC does show the degree to
which you're banked.
The turn coordinator shows direction and rate of turn but no bank angle.
You can do a skidding standard rate turn with the wings level by applying
rudder in one direction and opposite aileron to keep the wings level. In a
coordinated turn it does somewhat show bank angle but the faster your
airspeed the more bank angle is required to achieve standard rate.
I agree with using the TC over the compass if it is avalable. Following is a
quote out of the Wikipedia, for what it's worth:
"Aircraft compass turns are used in an aircraft when other directional
instruments, such as the directional gyro or turn coordinator, have failed."
http://en.wikipedia.org/wiki/Aircraft_compass_turns
Allen
Old August 25th 06, 04:31 PM posted to rec.aviation.ifr
Jose[_1_]
you're banked.
The TC does not show bank. It shows rate of turn, and has a temporary
indication of bank intended to "lead" the turn indication. If you slip
or skid, the TC will shortly indicate "straight" (non turning) flight.
Even though you are banked, you are going straight.
Nonetheless, it's what I would use as primary, if I only had that and
the whiskey compass.
Jose
Old August 25th 06, 05:58 PM posted to rec.aviation.ifr
Gary Drescher
"Jose" wrote in message
t...
whereas the TC does show the degree to which you're banked.
indication of bank intended to "lead" the turn indication. If you slip or
skid, the TC will shortly indicate "straight" (non turning) flight. Even
Nonetheless, it's what I would use as primary, if I only had that and the
whiskey compass.
Yup. The crucial point is that the inclinometer tells you about slipping or
skidding. So if it's centered, then the TC indeed tells you whether you're
banked or level.
--Gary
Old August 25th 06, 06:20 PM posted to rec.aviation.ifr
Robert M. Gary
you're banked.
In a full panel your primary bank is, of course, your heading indicator
in straight flight. Yet it also does not indicate bank angle.
Actually the compass is very predicatable in a standard rate turn and
its effect is well known and commonly taught to students as "compass
turns" as described in the FAA publication I posted earlier.
You are describing "timed turns". That is a different technique than
"compass turns". Both are commonly taught to instrument students in the
U.S. and both result in very exact heading changes when understood.
Both are very difficult in turb though.
-Robert, CFII
Old August 25th 06, 06:23 PM posted to rec.aviation.ifr
Robert M. Gary
In straigtht and level flight under partial panel the compass would
have to be primary because the TC cannot tell you if you are still on
the correct heading. Corrections would be made with the TC though. Just
like full panel when your DG is primary in straight flight. It is very
possible to roll out to a heading within 2 degrees in any direction
using "compass turns" technique.
-Robert, CFII
Old August 25th 06, 07:36 PM posted to rec.aviation.ifr
Pixel Dent
t...
whiskey compass.
banked or level.
--Gary
Just two weeks ago I had the wonderful experience of a real live vacuum
failure in the middle of clouds over a 200' ceiling. TC with
inclinometer to keep the wings level and GPS for navigation got me
safely down with help from ATC. I'd check the whiskey compass about once
a minute to make sure nothing was lying to me.
I always practice partial panel approaches without the GPS, but when it
happened in real life I was very happy to have it as a workload reducer.
Old August 25th 06, 08:11 PM posted to rec.aviation.ifr
Jim Macklin
I took the question to be either/or. What ever instrument
you are intending to keep at a constant, whether heading,
altitude or airspeed or RC, is your primary, but control
often is not done using that instrument.
If the choice was you have only one instrument that shows
any heading related indication, which would be primary
[compass or TC] then the compass must be primary, but the TC
would be "primary for control" and would get the scan
priority between what ever pitch instruments, the compass
might be scanned only 2% of the time with a majority of the
time on the TC/altimeter and a/s.
I further said that is all you had was the compass, then a
south heading would be best because it eliminates the
backwards turning error and magnifies the beginning of a
turn and in the correct direction...
be
[needle],
compass would
are still on
though. Just
flight. It is very
direction
| -Robert, CFII
Old August 25th 06, 10:55 PM posted to rec.aviation.ifr
On 25 Aug 2006 09:20:56 -0700, "Robert M. Gary"
you're banked.
Most of you guys are far better qualified as I only have an IMC
rating. This is less demanding and only valid in the UK. Only 15 hours
training are required so to keep things simple I was told to use the
second VOR dial as a reminder of present heading by setting heading at
the top of the dial. When you make a turn you don't need any maths but
look where you need to be on the VOR dial and convert it visually to a
clock face. If for example you need to turn 120° right that's 20 past
on a clock therefore double and time 40 seconds.
Timing is simply bank into a rate one turn and visually add 40 seconds
to the clock hand (or could use a timer). The only calculation needed
is to double the interpreted time. Hopefully I'll only have to use it
when renewing the rating every couple of years.
As has already been mentioned the easier way is to use the ADF needle.
Stupid Question Crash Lander Piloting 35 July 23rd 06 03:39 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 09:14 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
