Legal or not?
Old August 31st 06, 12:34 AM posted to rec.aviation.ifr
Robert M. Gary
Default Legal or not?
Jim Macklin wrote:
GPS can substitute for the ADF. Radar can substitute also.
So, if the acft has no ADF or the NDB is OTS, so, it could
be.
Are you sure radar can be? When an ILS says "ADF Required" I believe
you must either have ADF or GPS. Usually if radar is good enough it
will say "ADF or Radar Required".
-Robert
Old August 31st 06, 12:55 AM posted to rec.aviation.ifr
Steven P. McNicoll[_1_]
"Rick McPherson" wrote in message
On Aug 28 I was practicing approaches at KAGC (FEW 008 BKN 012 OVR 025 4SM
BR). My preflight brief indicated that the McKeesport NDB is out of
service. Yet, the ATIS identified runway 28 as active and we were given
the ILS 28 approach for practice (upon request). Is this approach legal
without the beacon?
http://download.aopa.org/ustprocs/20...ils_rwy_28.pdf
Yes.
As a side note, is the equipment that you fly still using ADF?
Yes.
Old August 31st 06, 12:59 AM posted to rec.aviation.ifr
"Brad" wrote in message
If MKP was a Radar Fix, they could.
Radar fix? What purpose does MKP serve if you're vectored to the localizer?
Old August 31st 06, 01:05 AM posted to rec.aviation.ifr
"Dane Spearing" wrote in message
The use of an approach certified GPS in lieu of an ADF is addressed in
AIM 1-1-19f. See:
http://www.faa.gov/ATPubs/AIM/Chap1/aim0101.html#1-1-19
In a nutshell, yes, you can use your IFR approach certified GPS in lieu
of an ADF for identifying the OM on an ILS approach, and/or for
identifying
a missed approach fix.
Use of GPS in lieu of ADF and DME is covered in that paragraph, but I see no
mention of use of GPS in lieu of a marker beacon receiver. While an ADF can
certainly identify an LOM, it won't identify an OM.
Old August 31st 06, 01:10 AM posted to rec.aviation.ifr
Nope, you're correct, its just a feeder route to the IAF. If MKP was
an intersection, you'd see MKP INT on the profile and plan view. The
076 line and arrow would extend all the way to the fix, rather than
just pointing towards the fix as the feeder route does. Distance and
angle did not meet the terps requirement to serve as a radial to
identify it as a intersection fix.
Why would the feeder route need to do any more than that? All the ADF does
on this approach is allow the pilot to navigate to the localizer. The
feeder route does that and so does a radar vector.
Since it was a practice approach (VFR I assume) it would be legal even
if the loc was out of service.
However, even as an acutal IFR approach it can still be given assuming
you can identify the ADF on your GPS.
Why would you need to identify the ADF?
Old August 31st 06, 01:33 AM posted to rec.aviation.ifr
Robert M. Gary
Well, in the case of the ILS SAC its because the course from the outer
marker is one degree off the localizer.
-Robert
Old August 31st 06, 01:51 AM posted to rec.aviation.ifr
Why would you need to identify the ADF in this case?
Old August 31st 06, 03:03 AM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Wednesday, August 30, 2006 3:13 PM
Posted To: rec.aviation.ifr
Conversation: Legal or not?
Subject: Legal or not?
Rick
Absolutely -- I just took my IPC 10 days ago and had to execute an NDB
intercept via own navigation, a 3 loop NDB hold, and an NDB approach.
Even though we had a GX55 on board, it was "failed".
After not having done any serious clock-work for 18 years, I came back
about 6 pounds lighter and dripping wet; but thank heavens the laws of
physics haven't changed.
Old August 31st 06, 03:09 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Posted At: Wednesday, August 30, 2006 6:06 PM
Ok, it's getting late and I haven't asked enough stupid questions today
so here goes: what is the difference between an Outer Marker and a
Locator Outer Marker? Aren't they the same frequency, same audio pattern
and tone?
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 12:55 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 11:43 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aviation Marketplace 0 May 11th 04 11:43 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Owning 0 May 11th 04 11:43 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Owning 0 May 11th 04 11:36 PM
