Hawker vs. Glider Midair - with photo!
Old September 6th 06, 09:56 AM posted to rec.aviation.soaring
Gerhard Wesp[_4_]
Default Hawker vs. Glider Midair - with photo!
Eric Greenwell wrote:
How many seconds does it take FLARM to compute a collision warning, once
the aircraft are within FLARM's radio range?
A warning is only issued if a dangerous approximation is detected. As
far as I understand, this information is updated every second. IOW the
algorithm doesn't have state that persists over position/velocity
updates. IOW, the warning is pretty immediate.
Regards
-Gerhard
Gerhard Wesp / Holderenweg 2 / CH-8134 Adliswil
+41 (0)76 505 1149 (mobile) / +41 (0)44 668 1878 (office)
+41 (0)44 668 1818 (fax)
http://gwesp.tx0.org/
  #72
Old September 6th 06, 10:21 AM posted to rec.aviation.soaring
Gerhard Wesp[_3_]
5Z wrote:
FLARM was designed for gliders and the speeds we fly. If it were
Objection. FLARM is a "collision-warning unit for sailplanes and light
aircraft." It's "movement prediction model" is "optimised for the
respective user." (from the manual). The FAQ states (in German) that
it's designed for ground speeds up to 249 kts and vertical speeds of up
to 256 m/s (the designers had skydivers in mind here . Range is given
between 1km and 5km, it strongly depends on how the antenna is mounted.
Regards
-Gerhard
  #73
Old September 6th 06, 03:03 PM posted to rec.aviation.soaring
Udo Rumpf
The last time I fell from an aircraft I dropped at
a leisurely rate of 60 m/s
Udo
. Range is given
antenna is mounted.
Regards
-Gerhard
Hawker vs. Glider Midair - with photo! Darkwing Piloting 151 September 5th 06 06:19 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Bad publicity David Starer Soaring 18 March 8th 04 04:57 PM
