#81
Stefan wrote:
Mxsmanic schrieb: When will true headings be used? Never, I hope, as it would render the whisky compass as a reliable navigation aid near to useless. Eventually, the magnetic poles will move so far that every station and aircraft everywhere will have to be recalibrated to account for it, and all charts will have to be changed. I'm hoping you fly with the newest maps. Mxs doesn't fly except in the back of an Airbus or with a computer monitor/Microsoft flight simulator. Take his remarks in that context. And the poles occasionally reverse, Occasionally... :-))) Stefan |
#82
RK Henry wrote: On Sat, 09 Sep 2006 00:09:20 +0200, Mxsmanic wrote: Thomas Borchert writes: And having true heading (and only that) changes this problem how? It doesn't. But true north doesn't move, and it's right at the top of standard maps. Except that apparently true north DOES move. The tsunami/earthquake of a year and a half ago reportedly caused the north pole to shift about an inch as well as decreasing the length of a day. Just goes to show, you can't depend on anything. RK Henry Not to mention that the pole itself moves around. See http://en.wikipedia.org/wiki/Chandler_wobble |
#83
Mxsmanic wrote:
Thomas Borchert writes: And having true heading (and only that) changes this problem how? It doesn't. But true north doesn't move, and it's right at the top of standard maps. Well, back in the 1400s or so, north was at the bottom of maps! |
#84
Stubby writes:
Well, back in the 1400s or so, north was at the bottom of maps! You need to buy some new charts. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#85
On Sat, 09 Sep 2006 20:31:27 +0200, Mxsmanic
wrote: RK Henry writes: Except that apparently true north DOES move. The tsunami/earthquake of a year and a half ago reportedly caused the north pole to shift about an inch as well as decreasing the length of a day. Just goes to show, you can't depend on anything. All earthquakes cause such effects. However, if they produce changes that are below the resolution threshold of avionics, they aren't a problem. The magnetic pole, on the other hand, moves perceptibly over time--enough to require new charts and new regulation of stations and instruments. So does GPS. The system changes over intervals of hours, with such factors as satellite outages or signal propagation, rather than the months or years that it takes for magnetic variations. Generally, the GPS computer applies corrections automatically. That makes it transparent to the user, but it doesn't mean that the system is inherently perfect. If GPS were inherently perfect, WAAS would be unnecessary. All instruments are inaccurate. In order to use them you have to calibrate them. RK Henry |
#86
Mxsmanic wrote: Stubby writes: Well, back in the 1400s or so, north was at the bottom of maps! You need to buy some new charts. Nah. They are on the walls of a museum somewhere. In Venice in the Ducal Palace of the Doge, I believe. But "north at the bottom" was the accepted convention. I don't know what made them change but that would be interesting, too. |
#87
Stubby schrieb:
Nah. They are on the walls of a museum somewhere. In Venice in the Ducal Palace of the Doge, I believe. But "north at the bottom" was the accepted convention. I don't know what made them change but that would be interesting, too. Maybe the magnetic poles reversed? :-P |
#88
Mxsmanic wrote:
In modern aircraft, a failure of electrical systems brings a lot more problems than mere navigation errors. No radio, no other navaids, no control surfaces in some aircraft, no propulsion in some aircraft. And while a compass shows magnetic north, that's all it shows. You have no idea how far north or south you are, or which direction to fly to your destination. You "fly" a PC flight simulator (game)... Even if the poles do shift, it's not going to effect your game, so don't worry about it... You are obviously on the wrong newsgroup... Perhaps you should go to comp.pc.ibm.pc.games.flight-sim or rec.aviation.simulators and leave this group for real pilots... |
| Thread Tools | |
| Display Modes | |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Magnetic reversal | Everett M. Greene | Instrument Flight Rules | 12 | April 9th 05 10:40 AM |
| Dynon EFIS D-10 Magnetic heading | Paul Lee | Home Built | 3 | November 15th 04 09:41 PM |
| Aircraft Magnetic Compass | Quilljar | Simulators | 5 | July 11th 04 04:08 PM |
| Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 01:08 PM |
